Go to Post If you're in Israel, it might be a long flight to the nearest Walmart - MrForbes [more]
Unread 14-01-2009, 13:54
2056Durfey 2056Durfey is offline
FRC #2056 (OP Robotics)
Rookie Year: 2007
2056Durfey will become famous soon enough2056Durfey will become famous soon enough
Disable Dongle
Does anyone know where to find the wiring diagram for this years disable switch for the driver station? Thanks.
Unread 14-01-2009, 14:40
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Disable Dongle
Go here: http://www.usfirst.org/community/frc....aspx?id=10934
chapter 3, bottom of page 7:
3.1.7 Competition Port Pinouts
The competition port is used to enable / disable the robot. A “dongle” is provided in the Kit of Parts
for teams to use for this purpose when not in a competition. If teams need to make a replacement
dongle or need additional spare dongles, a team-constructed dongle can be fashioned by
connecting pins 8 and 9 of the competition port to a switch. NOTE: it is essential that the other pins
of the connector be left unconnected, as some of the other pins contain power and/or ground –
accidentally shorting other pins of this connector can permanently damage the Driver Station.
An inexpensive dongle (shown in the photo below) can be fashioned out of components readily
available locally:
• PC Board Toggle Switch SPST
• D-Sub Connector 9 pin male
• D-Sub Connector Hood sized to fit
There is a picture on page 8 that might be helpful.
Unread 14-01-2009, 22:44
Rookie Year: 2007
Re: Disable Dongle
Thank you! That was very helpful, I guess I missed it when I was looking.
OI Disable Switch function??? jonboy Control System 1 12-02-2008 10:00
Disable Encoders Problem mftaberner Programming 10 09-02-2007 23:26
Autonomous enable/disable Culvan Van Li VEX 4 21-09-2006 13:03
Bypass Disable Switch jakep Control System 36 19-08-2006 12:46
