Go to Post Givens do not need solutions. - Al Skierkiewicz [more]
Unread 14-01-2009, 14:29
mjcoss mjcoss is offline
FRC #0303
mjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the roughmjcoss is a jewel in the rough
Wondering if anyone else is having an issue with Joysticks
I'm writing some code to help the team prototype some drivetrain ideas. As a quick hack, I defined 2 joysticks and was going to use the joystick triggers to control some steering motors. I'm using the WindRiver workbench, and I used the simple template. In the OperatorControl() function I created 2 Joystick objects, and used GetTrigger(). Doing something like this:
Code:
        Joystick *left_stick, *right_stick;
        left_stick  = Joystick::GetStickfromPort(1);
        right_stick = Joystick::GetStickfromPort(2);
       while(isOperatorControll()) {
			if(left_stick->GetTrigger()) {
				left_steer.Set(.5);
			        right_steer.Set(.5);
			else {
				left_steer.Set(0.0);
				right_steer.Set(0.0);
			if(right_stick->GetTrigger()) {
				left_steer.Set(-.5);
				right_steer.Set(-.5);
			else {
And yes I know that both triggers down isn't being handled.
The odd thing is that the left_stick trigger works just fine (turning on/off the motors), but the right_stick trigger doesn't work at all. Commenting out the left_stick GetTrigger() block of code, and now the right trigger starts working. I've tried allocating the joystick on the stack, using new directly, etc. Bottom line is that I can get only one trigger working at a time. I'm using the KOP joysticks. I'm going to hook up a serial port and put some debug prints but was curious if anyone else is seeing the same thing. I do know that the the GetAxis functions are working because, using the same declarations for the joysticks, I was able to get the TankDrive() function to work properly.
Is anyone else having this problem hpman247 Programming 10 27-11-2008 02:57
Anyone Else Having Problems with Q&A on FIRST? Windwarrior General Forum 6 25-01-2006 10:54
Anyone else having trouble keeping up with work? D. Gregory General Forum 36 28-03-2004 16:55
Anyone else having trouble with Yahoo mail services? Elgin Clock IT / Communications 12 20-03-2004 16:59
Anyone else having trouble with the pneumatics manual? Stu Bloom Pneumatics 15 13-01-2004 01:13
