Go to Post Sir, you vastly underestimate the destructive power of a teenager. - DonRotolo [more]
Thread Tools Rating: Thread Rating: 6 votes, 4.50 average. Display Modes
Unread 14-01-2009, 15:43
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
void* pointer to object in C++
I have been at this for some time now, and this won't compile:
Code:
(function(int data))
void * MyPointer
if (data=0)
     Gyro gy(1);
     MyPointer = &gy;
if (data=1)
     Ultrasonic gy(1);
     MyPointer = &gy;
if (etc...
etc...
(function2(int data2))
if (data2=0)
     return MyPointer->GetValue(); //this produces error: 'void*' is not a pointer-to-object type (:eek:)
etc...
You can probably see what i am doing, (accessing different function based on sensor type), and Nothing has worked
Aiming that remote: Laser pointer allowed? efoote868 Rules/Strategy 9 02-03-2008 21:01
Pointer to pwm bronxbomber92 Programming 5 07-02-2008 15:57
Suspicious pointer conversion ebowla Programming 2 26-01-2008 12:13
laser pointer 1574aviad Technical Discussion 9 20-02-2005 20:25
problem with void Process_Data_From_Local_IO CmptrGk Programming 2 29-01-2005 17:14
