Driver Station Update
We are having a problem with setting up. We did the update and held the down button after for a while, and it still didn't work, so we unplugged it, and re-plugged it in, and waited 2 min b4 doing anything, and tried again, but we were unsuccesful, then we discoverd are dongle switch won't switch from enabled to disabled. What do we do to fix this, can we reset completly? Any suggestions?
Re: Driver Station Update
We are really stuck can anyone help plz?
So I'm guessing you can't set your team number on the DS?
What is displayed on the DS screen on the bottom line? As far as the dongle goes - does the DS screen say "Enabled?" And you can't get it to say "Disabled?" Even when you completely disconnect the dongle from the Ds altogether? |
The dongle problem is probably just a fault in that little switch on it.
If you have a multi-meter try testing the pins while you flip the switch to see if it's operating properly. The motors not running is probably a separate problem. How far did you get in your setup? Did you bench test the control system? After that did you reflash the cRIO and the Driver Station? Were you able to set your team number on the DS? Is your DS plugged directly into the cRIO with an ethernet cable or are you using the wireless? Has the wireless router/bridge been setup? |
We tested the entire control system, motors, and everything worked, up until the point where we tried to change the team number I'll see tomorrow Direct link with ethernet cable to cRIO wireless has been setup |
Okay this is what the display says on the DS:
On the DS push and hold the "up" arrow button for what seems like a minute.
TY SOOOO much it worked!!! TY for all the help!
| driver station firmware update | bobbyt14 | Programming | 15 | 14-02-2009 15:05 |
| Driver Station firmware update failure | ofshea | FRC Control System | 8 | 13-01-2009 11:35 |
| 2nd Driver Station | bcharbonneau | General Forum | 2 | 09-01-2009 14:19 |
| Driver Station Help.. | 1708xMr.Roboto | FRC Control System | 8 | 22-12-2008 15:24 |
| Driver Station Setup?? | Team 1708 Dave | Programming | 9 | 19-12-2008 23:09 |
