Go to Post In the end, people can throw all the stories at me they want, but I'm never going to let mere stories convince me physics is wrong. - AdamHeard [more]
Unread 15-01-2009, 16:02
Ratchet1's Avatar
Ratchet1 Ratchet1 is offline
THIS IS SPARTA!!!!
FRC #3062
Team Role: Student
Rookie Year: 2007
Ratchet1 is an unknown quantity at this point
4WD vs. Chain Drive
Right now we are trying to figure out whether we should use a 4WD system with motors on all 4 wheels, or a chain system with 2 motors. Any suggestions?
Unread 15-01-2009, 16:13
Bob Steele's Avatar
Bob Steele Bob Steele is offline
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Re: 4WD vs. Chain Drive
Either would work for you. Just remember that you need to power any wheels that in contact with the floor to give yourself the best acceleration at possible.
You can, of course do 4WD with two motors and chains to all wheels.
In this game I would really doubt if you will need 1 motor per wheel because the friction is so low that you can't apply much torque to the wheels anyway.
Two motors is lighter...
Good luck!!
Robert Steele
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 15-01-2009, 16:17
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Please search these forums. There are several discussions regarding the advantages of both.
No for my opinion (Warning, Warning, opinion on the loose)
This year's game definitely takes some prototyping and mathematical analysis to make many decisions, the drive train is a perfect example. For the approach we are taking this year, we have decided to not try to go with lots of power for the drive train. Instead, we are minimizing torque by limiting the gear reduction, using just two motors and doing a little coding magic.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 15-01-2009, 16:43
Ratchet1's Avatar
THIS IS SPARTA!!!!
FRC #3062
Team Role: Student
Rookie Year: 2007
ok. Thanks for the help. And i did look, and couldnt find anything on it, thats why i started a new thread.
Unread 16-01-2009, 07:41
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
2 CIM motors with the gear ratios from the kit transmissions provide more than enough power for this years' surface.
4 motors would make you go no faster nor push harder (it would allow you to use higher gear ratios, I suppose).
The difference comes down to what is easier to mount in your frame.
Unread 16-01-2009, 09:59
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
If you go the 4WD route it could give you the opportunity to monitor each wheel and reduce power if it starts slipping too much...
Unread 16-01-2009, 10:03
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you go with the chain, 2 motor, 4wd design you could monitor the speed of both wheels on each side, and reduce power if they slip too much. No need to have the wheels driven independently to do this, the wheels on each side of the robot will slip about the same amount (in the forward direction).
Unread 16-01-2009, 10:07
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Your assumption, here, is that the weight of the robot is roughly equal on all wheels. This assumption may, or may not, be true, and will give different results with different CoM.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 16-01-2009, 10:10
MrForbes's Avatar
AKA: Jim
No, my assumption here is that you are not turning too sharply.
If the wheels are connected by a chain, they will turn the same speed...doesn't matter how much weight is on each one.
Might be that you were confused by my brief wording. What I mean is that on each side of the robot, the two wheels on that side will slip about the same amount, so you can implement slip control on a "per side" basis, instead of a "per wheel" basis.
Hope this makes it more clear!
Unread 16-01-2009, 10:15
Mad Scientist
AKA: Me
FRC #2040 (DERT)
The side will slip when the wheel with the least amount of traction breaks free because once that happends all of the torque from the slipping wheel will go through the chain to the non-slipping wheel and that will cause it to slip as well.
Thus 4 independently driven wheels will be slightly better ... although with traction control you may be able to compensate for the differences.
___________________
- Tennyson, Ulysses
Unread 16-01-2009, 10:41
MrForbes's Avatar
AKA: Jim
All of the torque? or the difference in torque between static and dynamic friction?
I agree that you can get a bit better traction with independent 4wd, but I also think you can do a lot with per side traction control.
In our case, we're using up all the motors on the ball handling stuff so it's a non-issue, we only have one CIM and one tiny Mabuchi motor (and the window motors) left for each side of the drivetrain.
Unread 16-01-2009, 10:19
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Hmm, interesting points above made me think of something.... Arguably, you could take 1 FP + 1 Banebots 545 through their own AM Planetaries into a toughbox and have that drive one side, with an identical setup on the other side. Estimations for worst-case here are that each motor pulls 5 amps when you're pushing. This is only doable because of the coefficient of friction though. So long as the chains drive all wheels that touch the ground, it would work ok. I'd argue that acceleration with this setup is very close to that of 1 CIM per side.
It's downside is that it adds much more complexity than needed and is somewhat expensive for what you get.
GitHub
Unread 16-01-2009, 10:22
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Also remember that the CoF on the carpet edges is different then the Regolith
___________________
- Tennyson, Ulysses
pic: AM Mecanum Chain Drive MrForbes Extra Discussion 5 19-09-2007 02:44
Chain drive vs. cogged belt drive(timing belts) LordBritten Technical Discussion 24 20-12-2006 23:07
Chain Drive chain Damelvin 3D Animation and Competition 2 15-02-2005 00:19
Chain Drive Question Matt_Kaplan1902 Technical Discussion 34 12-04-2004 14:21
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
