Go to Post That's right 10 years and this is the first time ever that the school wanted anything to do with the FIRST team. - RoteAugen [more]
Unread 15-01-2009, 17:20
Mike Mahar Mike Mahar is offline
FRC #0138
Mike Mahar will become famous soon enough
Telling drivers station your alliance
You can ask the drivers station which alliance you are on (kRed, kBlue) but how do you tell the drivers station? Is it a wire on the competition port? I'd like to use this information to control which trailer to track with the camera but I'm reluctant to do it if I can't test it. I'd hate to gamble that this function works and find out at the regionals that it doesn't.
Unread 15-01-2009, 17:42
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Telling drivers station your alliance
Mike,
The simple thing for the field controller to know which alliance is which is the side to which it is wired. However, you will know which alliance you are on. A simple switch read by a digital or analog input can easily trigger your code to search for one color goal or the other.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 15-01-2009, 17:43
Unsung FIRST Hero
Nate Smith Nate Smith is offline
FRC Key Volunteer Trainer
AKA: CrazyNate
Rookie Year: 1998
Nate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to behold
Send a message via AIM to Nate Smith Send a message via Yahoo to Nate Smith
Without further information being released by FIRST to the contrary, I'm guessing this signal is provided through the ethernet connection to the Field Management System(FMS). Because of this, there is no easy way to simulate this outside of an official FRC field. What I would recommend as an alternative is designing two sets of code, one with the alliance detection and one without, and run tests during practice day to see what the outcome is. However, on the positive side, if it is in the C++ libraries, I'm guessing it's already been tested by the developers and working...
When in doubt,you could always ask on Q&A...
Nate Smith
nsmith@smythsoft.com
12 seasons, 4 teams, and more time logged behind the scorekeeper's table than I care to remember...
returning for 2011? only time will tell...
Unread 16-01-2009, 07:21
FRC #0138
Yes, adding a switch to the robot or the driver's station is easy enough but it is also easy to forget to set the switch in the heat of the competition and then your tracking is worse than useless. If you put the switch on the robot you lose the ability to correct is for the whole match. If lyou put it on the driver's station, then the information doesn't get to the robot during autonomous mode. Hopefully, the new field management system will allow driver station inputs during disabled mode.
That is why I'd like to use the built in alliance function.
Unread 16-01-2009, 14:12
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
It does get to the robot before autonomous mode, however. The joysticks and switches can be read while the robot is disabled, before the match begins.
(This assumes that the field control will work approximately the way it has for at least the past five years, with the state changing directly from teleoperated/disabled to autonomous/enabled, with no autonomous/disabled in between. If things have changed to be autonomous/disabled on powerup before the match starts, then a switch on the operator console won't work.)
Unread 17-01-2009, 08:43
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Also, don't forget there is a User Swith on the cRIO that can be read from the code. That is how we are planning to set which alliance we are on.
Telling the drivers station your alliance Mike Mahar Technical Discussion 2 17-01-2009 12:24
pic: Drivers of the Winning Alliance JYang Extra Discussion 2 26-10-2008 21:55
Telling alliance in the code Andrew Schreiber Programming 4 30-01-2008 10:30
How does your team pick your drivers? Tton General Forum 14 08-04-2003 20:54
Members of alliance station... archiver 2001 2 24-06-2002 01:26
