A List of Problems
Okay so as of yesterday I installed the firmware update on the DS, I posted a thread and got the answers to fix it, however, after I updated the DS with the firmware I updated the DS with our team number. I then restarted the the DS and then looked at it the Victor 884 speed controllers and they were flashing an orange light, and they were working before I installed the firmware update, but now after, the Victors just flash, we tried the dongle and it doesn't work on either enabled or disabled. So any suggestions on what to do?
Re: A List of Problems
Did you also update the firmware on the cRIO (V7)?
After the firmware update the DS won't talk to the out-of-the-box cRIO. |
No we didn't update, so I'm guessing we do the update through the tether right? And we get the update from the FIRST site... I believe not sure
hold on where do you find the update for the cRIO?
You get the updates from the FIRST site.
The cRIO update is embedded in the latest LabVIEW Update 2. After you've installed Update 2, start the "FRC cRIO Imaging Tool" (it'll be on your desktop). Choose "Format Controller" Enter a Device Name of "FRC-cRIO-2429" and enter your team # It'll take about 5 minutes to complete the update. P.S. The directions are in the Control System manual section 5.1.2 Last edited by Mark McLeod : 15-01-2009 at 19:15. |
Okay we updated LabView V2 on the computer, opened up CompactRIO Imaging and it says:
Everything's powered up - DS, cRIO?
Everything's connected? Your PC to the DS ETH2 port The DS ETH1 port to the cRIO port 1 Your PC is set to an IP of 10.24.29.6 and subnet mask of 255.0.0.0 Firewalls need to be turned off on your PC. If you have a network card that should be turned off too. There are a bunch of PC things that block or obstruct network access. Last edited by Mark McLeod : 15-01-2009 at 20:29. |
Okay update of both cRIO, and DS is officially over with, yeah!
But now 1 more problem, I hope, and then I think we are good, I realized when I tried to download code, the code didn't go on. To test this theory I flipped the autonomous switch, and the supposed prewritten autonomous didn't run, so I know 100% it's with the target or something, so do you have to set the target, how, and where to? Anything else we should know for downloading code?? TY for the help ![]() |
It depends first on what code you started with:
-- LabVIEW Basic or Advanced or one of the examples? -- Wind River template or example? When you switch to autonomous does the status light on the Digital Sidecar start to blink by any chance? If you're using a LabVIEW Basic/Advanced Framework then you set your Target IP when you first create your project. If you forgot to then you'll see it in the Project Explorer as: "RT CompactRIO Target (10.xx.yy.2)" |
#10
Okay we are using WindRiver, example, not template.
So I see on the top bar there is a target option, so I'm not sure what to do... can you help us? ![]() |
#11
Anyone know how to set the target, using Wind River example?
| To-Do List | synth3tk | CD Forum Support | 3 | 14-01-2009 18:37 |
| Labview problems and code problems | ajsetter | Programming | 25 | 18-01-2006 17:07 |
| Waiting List | Weeeeeeeee | Championship Event | 4 | 06-04-2003 20:45 |
| Match List | Jack | OCCRA | 11 | 03-01-2003 12:33 |
| Contact List... | archiver | 2001 | 1 | 24-06-2002 01:59 |
