Go to Post If you want to have other teams cheer for you all day long at competition, name your team "Robot Coming Through". - Gary Dillard [more]
Unread 15-01-2009, 18:37
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
A List of Problems
Okay so as of yesterday I installed the firmware update on the DS, I posted a thread and got the answers to fix it, however, after I updated the DS with the firmware I updated the DS with our team number. I then restarted the the DS and then looked at it the Victor 884 speed controllers and they were flashing an orange light, and they were working before I installed the firmware update, but now after, the Victors just flash, we tried the dongle and it doesn't work on either enabled or disabled. So any suggestions on what to do?
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 15-01-2009, 18:53
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: A List of Problems
Did you also update the firmware on the cRIO (V7)?
After the firmware update the DS won't talk to the out-of-the-box cRIO.
Unread 15-01-2009, 18:55
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
No we didn't update, so I'm guessing we do the update through the tether right? And we get the update from the FIRST site... I believe not sure
Ben Kellogg
Unread 15-01-2009, 19:00
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
hold on where do you find the update for the cRIO?
Ben Kellogg
Unread 15-01-2009, 19:05
Just Itinerant
You get the updates from the FIRST site.
The cRIO update is embedded in the latest LabVIEW Update 2.
After you've installed Update 2, start the "FRC cRIO Imaging Tool" (it'll be on your desktop).
Choose "Format Controller"
Enter a Device Name of "FRC-cRIO-2429"
and enter your team #
It'll take about 5 minutes to complete the update.
P.S. The directions are in the Control System manual section 5.1.2
Unread 15-01-2009, 19:52
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Okay we updated LabView V2 on the computer, opened up CompactRIO Imaging and it says:
No CompactRIO devices were found. Verify the network connection.
We rescanned the drive, but stil same message, so what should we do?
Ben Kellogg
Unread 15-01-2009, 20:23
Just Itinerant
Everything's powered up - DS, cRIO?
Everything's connected?
Your PC to the DS ETH2 port
The DS ETH1 port to the cRIO port 1
Your PC is set to an IP of 10.24.29.6
and subnet mask of 255.0.0.0
Firewalls need to be turned off on your PC.
If you have a network card that should be turned off too.
There are a bunch of PC things that block or obstruct network access.
Unread 20-01-2009, 00:31
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Okay update of both cRIO, and DS is officially over with, yeah!
But now 1 more problem, I hope, and then I think we are good, I realized when I tried to download code, the code didn't go on. To test this theory I flipped the autonomous switch, and the supposed prewritten autonomous didn't run, so I know 100% it's with the target or something, so do you have to set the target, how, and where to? Anything else we should know for downloading code?? TY for the help
Ben Kellogg
Unread 20-01-2009, 10:06
Just Itinerant
It depends first on what code you started with:
-- LabVIEW Basic or Advanced or one of the examples?
-- Wind River template or example?
When you switch to autonomous does the status light on the Digital Sidecar start to blink by any chance?
If you're using a LabVIEW Basic/Advanced Framework then you set your Target IP when you first create your project. If you forgot to then you'll see it in the Project Explorer as:
"RT CompactRIO Target (10.xx.yy.2)"
Unread 20-01-2009, 19:04
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Okay we are using WindRiver, example, not template.
So I see on the top bar there is a target option, so I'm not sure what to do... can you help us?
Ben Kellogg
Unread 21-01-2009, 09:38
ExarKun666's Avatar
AKA: Ben Kellogg
FRC #2429 (LCEC)
Anyone know how to set the target, using Wind River example?
Ben Kellogg
To-Do List synth3tk CD Forum Support 3 14-01-2009 18:37
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
Waiting List Weeeeeeeee Championship Event 4 06-04-2003 20:45
Match List Jack OCCRA 11 03-01-2003 12:33
Contact List... archiver 2001 1 24-06-2002 01:59
