Go to Post Whenever we loose a committed member of FRC, our entire country pays the price. - daniel_dsouza [more]
Unread 16-01-2009, 08:37
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
Team Role: Coach
jbbjjbt is an unknown quantity at this point
[FTC]: New LabView Templates
Ftctraining.com has new LabView and NXT-G templates. See here for the LabView:
http://www.education.rec.ri.cmu.edu/...view/index.htm
Now if only someone (HINT) could add in Phils battery code.
Now I have a question, Am I the only one that doesn't believe a disable command will stop any of the templates in autonomous? It seem that anything you put in the autonomonus section will completely run before the bluetooth is checked again for a disable command. It seems some sort of parallel loop needs to be added to check the bluetooth and disable the autonomous. To me the teleop works because you continuously loop through the code and check for the disable command.
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
[FTC]: LabVIEW Programming Template for FTC Team 288 FIRST Tech Challenge 30 06-02-2010 17:49
[FTC]: Tips page on using FTC Encoders with LabVIEW PhilBot FIRST Tech Challenge 7 27-01-2009 14:00
[FTC]: First problem with FTC and LabView.....? PhilBot FIRST Tech Challenge 5 07-11-2008 10:36
[FTC]: FTC Servo-Motor Problem with Labview dnhansen FIRST Tech Challenge 1 26-10-2008 00:43
[FTC]: FTC Labview questions Monty Python FIRST Tech Challenge 8 14-10-2008 20:03
