Go to Post Rules from prior years DO NOT APPLY to this year! - dlavery [more]
Unread 16-01-2009, 11:06
crazilyrandom1 crazilyrandom1 is offline
FRC #0365
crazilyrandom1 is an unknown quantity at this point
[FTC]: Help requested, the NXT is not showing the battery as being connected.
We have had this problem with two different robots now. The 10 cell Orion is not being showed as connected on the Lego NTX. This makes it so that our program is not allowed to run. Any insite or help would be gladly apreciated. Thanks
Unread 16-01-2009, 14:39
jbbjjbt jbbjjbt is offline
VRC Coach
AKA: Jon T
VRC #0177 (Twisted Botz)
Team Role: Coach
jbbjjbt is an unknown quantity at this point
Re: [FTC]: Help requested, the NXT is not showing the battery as being connected.
Double check that all of your wiring is correct. Check to see that the fuse in the battery is good. Use a voltmeter to measure the voltage on the motor controllers to make sure you are getting 12V nominal (13-14 actual). Is your battery charged?
Jon Thompson
Coach
VRC 177 Twisted Botz
Sponsored by FRC 122
NASA Knights
Unread 17-01-2009, 11:24
emmell's Avatar
emmell emmell is offline
Murphy was an Optimist!
AKA: Mannie Lowe
no team (Radbotics, RoboKnights, CircuitRunners, Oscar, and more...)
Team Role: Coach
emmell is just really niceemmell is just really niceemmell is just really niceemmell is just really niceemmell is just really nice
Also check to make sure that your motor controller is plugged into Sensor Port 1 on the NXT. If you are using ROBOTC, download the latest version (1.46 as of now). One last thing to do is to scan the forums on www.robotc.net. I recall seeing some discussions about low voltage and other issues with the 12VDC battery earlier in the season.
Good luck
Mannie Lowe
FIRST Program Manager - Center for Mathematics and Science Education - University of Mississippi
Mississippi FIRST Tech Challenge Affiliate Partner
paper: Reading the FTC Battery Voltage PhilBot Extra Discussion 4 16-01-2009 08:46
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
Lie down the battery or not?! Nadav Gross Technical Discussion 8 03-02-2007 22:26
CMUCam Forum messages are not being poseted as recent activity in the portal Bob22341 CD Forum Support 3 31-01-2007 22:34
Anyone concerned about the possibility of not being allowed to go to Nationals? skrussel Championship Event 41 03-04-2003 11:35
