Go to Post There are laws of physics, useful rules of thumb, and cold hard economics that come into play to be sure but at it's core Engineering is Art. For these artists, there is no substute for the sound engineering judgement. - Joe Johnson [more]
Unread 16-01-2009, 14:21
Team2883's Avatar
Team2883 Team2883 is offline
FRC #2883
Team2883 will become famous soon enoughTeam2883 will become famous soon enough
Servos, DSC and labview
Has anyone hooked up a servo to the DSC and ran it in labview. If so how did you do it. If you could help us out that would be great.
Unread 16-01-2009, 14:34
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Servos, DSC and labview
Yes. First, you need to put a jumper on the pins next to the PWM ports you want to use for servos. Next, use the open/get/set servo vi's in LabVIEW to operate them.
Unread 16-01-2009, 14:47
Team2883's Avatar
FRC #2883
Luke thanks a ton.
Labview Servos quizbiz NI LabVIEW 5 09-01-2009 08:48
Working with spikes and servos in labview EROCK Technical Discussion 2 07-01-2009 11:38
Labview NXT Servos quizbiz National Instruments LabVIEW and Data Acquisition 1 30-12-2008 14:42
Rack and Pinion/Motors and servos psniffler Motors 7 25-01-2008 16:16
servos and the camera incognito_NICK Programming 5 09-02-2005 00:00
