http://www.youtube.com/watch?v=RZqiDivs1KQ
can anyone help me to understand how the rover wheels are moving ? |
Re: how the wheels are moving in this video?
when you look when it's off the regloth, you can see them moving sort of.
when it's turning, the wheels moving and then you can sort of see them moving over the regloth. it would help if the camera was closer so we could see it |
also. if you look closely in the middle of the wheels, you can see the black part turning
That's a coaxial swerve drive, so each wheel is powered by a sprocket through the top and is able to be turned by a sprocket on the same axis. Here's a picture of a swerve module used by 148 last year, it should help you understand how they work. The small sprocket turns the whole module, and the large one is attached to the bevel gear by a shaft.
thanks alot for all we got the answer
Just wondering, what do you guys use to attach the swerve modules and allow them to spin? (I.E. between the U bracket and the first sprocket in the picture) Turntables? Thrust bearings? This is the last major thing i don't understand about crab/swerve drive. Any help would be great.
http://www.chiefdelphi.com/forums/at...5&d=1232211044 Last edited by Seat Ninja : 17-01-2009 at 22:26. |
thx for the pic it help us alot
| How many wheels are you going to use this year | midway78224 | Technical Discussion | 23 | 14-04-2009 20:49 |
| How are all the rookie teams doing this year? | WakeZero | General Forum | 20 | 21-02-2009 12:02 |
| how are we going to do this | omega | Programming | 2 | 22-03-2004 11:32 |
| Moving beyond boxes on wheels. | jon | General Forum | 29 | 07-04-2003 06:14 |
| So how are things looking this weekend? | archiver | 2001 | 1 | 24-06-2002 02:43 |
