Go to Post It's not all about the offensive "powerhouses", strategy is key. - smurfgirl [more]
Unread 17-01-2009, 15:52
DavidB DavidB is offline
FRC #2753
DavidB will become famous soon enoughDavidB will become famous soon enough
Ultrasonics: Will it work and how to make it work
My question is in regards to ultrasonics. This is the ultrasonic sensor my team was thinking of purchasing:
http://www.sparkfun.com/commerce/pro...oducts_id=8502
1. Will this work with the control system?
2. If so what how would I wire it? I'm figuring connect to PWM and plug into Analog breakout.
3. What kind of connections do ultrasonics typically have (Power, ground, signal etc...)
4. What do you think of this model and brand. Do you know any better types?
Thank you for any help you can provide.
DavidB
Unread 17-01-2009, 16:15
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: Ultrasonics: Will it work and how to make it work
1. It should work. There is a built-in class in WPILib to control and ultrasonic sensor.
2. I believe that would work.
I don't know much about 3 or 4 (we last worked with them in 2007). All I can say is that they were the most reliable sensors we worked with.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 17-01-2009, 16:27
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
Team Role: Leadership
Rookie Year: 2000
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
Post Re: Ultrasonics: Will it work and how to make it work
I have worked with ultrasonic range finders in some of my projects back in the day. The fun thing with them is the sound pulse they emit is conical (radiates in a cone shape from the speaker element) and it can generate a feedback wave from the ground. Also, they like the target to be a solid object. If you are looking to target the trailers, you might have a problem because they are mostly air.
Here are some things to look out for:
1) Draw the cone in a 3D CAD model and make sure nothing is inside the cone before your intended target.
2) The sensor has a minimum effective distance (somewhere between 4"-6" usually - this should be on the spec sheet) so make sure your target never gets closer than the minimum distance.
3) Ignore values higher than some optimum distance. Eg: If you intend to start acquiring your target at 20", ignore values greater than 25" because they could be junk reflections from objects other than your target.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Code To Make The Radio Work kE7JLM Programming 7 17-10-2007 20:41
Make your CAM2 work great! pafwl General Forum 0 06-04-2007 22:12
How do you make your compressorless system work, when all valves "bleed" air slowly? kmcclary Pneumatics 9 17-02-2007 21:01
Steps to make cam work? magical hands Programming 7 31-01-2006 17:43
How to Make MS joystick work/has anyone used it in past? andhesayz Control System 25 17-01-2005 10:34
