Go to Post Because after Kickoff....ZOMBIE MODE, HERE WE COME! - Dorienne [more]
Unread 17-01-2009, 18:18
electrowave89 electrowave89 is offline
FRC #0869
electrowave89 is an unknown quantity at this point
Workbench is not working. Need help Please
We have been trying to get workbench installed so that we can start programming. We originally had problems with our licensing not working correctly. We now have the license working but after we installed workbench we dont have an executable to run workbench. We checked the start menu under national instruments and it was not there so we went through c:\windriver\workbench 3.0\ and there is no executable anywhere in this route. We also do not see any executable in route c:\program files\national instruments\ . We have tried uninstall and reinstalling and still no luck. We definitely installed workbench also. Inserted DVD 2 and ran through installation, also ran through updates from the FRC website.
Not sure if it helps but running on Vista as well. Any suggestions you have would be greatly appreciated.
Thank you,
Team 869
Unread 17-01-2009, 18:42
FRC #0869
Re: Workbench is not working. Need help Please
Also note that the install does not give us all the options that the screen shot from the FRC website shows. Attached is a screen shot of our install options.
Name:	install print screen.jpg
Unread 17-01-2009, 20:49
elstaqub elstaqub is offline
Purported Programming Mentor
AKA: Ed Staub
FRC #0131 (C.H.A.O.S.)
elstaqub is an unknown quantity at this point
Been there, done that, I think. Did you get a 30-day activation code that you got direct from WindRiver, instead of using the default one that pops up? When I tried that, I got what you are seeing.
See http://forums.usfirst.org/showthread.php?p=24339
Yours in shared frustration,
-Ed Staub
Unread 18-01-2009, 22:33
FRC #0869
Well somehow the LAC began to work. After installing and uninstalling it just decided it was time lol. But our new issue is that it does not look like it has the option to install workbench at all
Unread 18-01-2009, 22:42
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
When I installed Workbench, somehow it also didn't end up anywhere in the start menu. I created a shortcut in my start menu to C:\WindRiver\workbench-3.0\wrwb\platform\eclipse\wrwb-x86-win32.exe and it launches fine for me that way.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 19-01-2009, 10:58
AKA: Ed Staub
7 minutes after your posting, I tried again... no joy. Sigh. It's going to be really hard to get this done with no tools!
Robot not doing what we need it to, and printfs aren't working Bryan Herbst Programming 8 21-09-2008 20:58
Need some help with arm not working... neilcooper Programming 3 15-03-2008 06:16
PLEASE HELP: OI switch box not working RbtGal1351 Control System 2 18-02-2006 19:34
reverse of motors NOT working please help Stillen Control System 4 11-02-2006 22:05
my comp is not working right and i need help Timmyd Chit-Chat 17 07-11-2005 23:39
