Go to Post On a team, saying "it's not my job" is simply not acceptable. - dlavery [more]
Unread 17-01-2009, 22:31
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
DS always disabled
We can never get our Driver Station out of the disabled mode.
Here is our setup:
Driver Station (eth1) connected to cRIO via crossover cable.
The driver station has software 2008_10_29a (most recent from WPIlib site).
The cRio has image 2009 v7 (most recent).
USB port 1 and 2 are connected to the kit joysticks
The competition dongle is connected in the enabled (down) position.
The DS is in tele-operated mode.
We turn on the DS and wait for it to boot. The screen indicates "Battery: N/A".
We turn on the cRIO. The DS briefly displays "Battery: No Code" then "Battery: 00.00V".
We connect the jumper in analog bumper 1, but even when we do this value is inaccurate, jumping around in the sub-1 volt range) We don't care about this issue too much at the moment, though it might be a related symptom.
The DS displays "Mode:disabled" and we are not able to get it to be enabled.
We have successfully built the sample code and we can upload it to the cRIO without any chance in symptoms.
The IPs of both the DS and the cRIO are verified to be correct. Our DS has the team number correct as well. There is indeed some communication going on as evident by the battery voltage status and ethernet activity.
I have looked throughout the forum and have not found problems relating to "stuck in disabled mode". We have had problems with this DS before (bum flash update). We sent it in and they told us there was a cold solder joint. They fixed it and gave us the board back, but we are suspecting that there might be something else wrong with it. Before going down that path, I'd like to make sure that we aren't missing anything.
(I don't have the equipment in front of me, so my display messages might not be 100% accurate)
Thank you very much.
Unread 17-01-2009, 23:01
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: DS always disabled
First, check your dongle. A broken wire or faulty switch will prevent you from enabling the system. Chapter 3 of the Control System manual says the switch is connected between pins 8 and 9 of the DB-9 connector.
Unread 17-01-2009, 23:17
intellec7's Avatar
108 programmer
AKA: Gustavo
Thanks for your reply, Alan.
I knew I forgot to mention something! We had tried shorting out pins 8 and 9 to no avail.
Unread 18-01-2009, 10:34
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
If it helps in your diagnosing...
The "enabled" / "disabled" message on the DS screen is unaffected by any other part of the system.
You don't need to power anything, other than the DS itself, to test if the dongle is working.
If directly connecting pin 8 to pin 9 didn't earn you the "enabled" message, then that's a DS hardware failure.
The only thing you have control over that could possibly affect it is the DS firmware upgrade.
Unread 18-01-2009, 10:47
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Although it wont help you, as you have probably tried both switch positions, but the "enabled" position on the toggle should be up, not down.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 18-01-2009, 14:38
intellec7's Avatar
108 programmer
AKA: Gustavo
Mark, that helps tremendously. Thanks! We have flashed the DS twice with the firmware.. We'll be contacting the KwikByte support.
Tanis, we opened the switch and probably mounted it back in backwards without realizing heh.
Unread 07-02-2009, 16:56
Terry Sherman's Avatar
Terry Sherman Terry Sherman is offline
Mentor -- Software
FRC #0093 (NEW Apple Corps.)
Terry Sherman is an unknown quantity at this point
We are having the same issue. Any luck contacting Kwik Byte? Any solutions offered?
We have the latest driver stations update (2009_01_22c1) as well as NI Update 3a.
When we turn on our Driver Station without anything elase other than power and the enable/disable switch, we can change from disabled to enabled.
When we add in the PC's ethernet, it still works.
When we connect *either* the cRIO via ethernet or connect the router via eithernet the DS will not exit disabled mode.
-Terry Sherman
Team 93 Software Mentor since 2003
Unread 07-02-2009, 17:20
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
I think it is the new update. Both of ours were fine before the update, now they both lock in"disabled" whenever we are connected to the cRIO. Does anybody have a copy of update 2? at least that one worked.
Former Mentor Team 1771
Former mentor Team 4509
Unread 08-02-2009, 13:20
Just Itinerant
I've seen this when the cRIO was at Update 2 and hadn't had Update 3a installed.
Restoring to the Oct DS firmware release does work, but reimaging the cRIO should work.
Unread 10-02-2009, 19:54
DillonMartine DillonMartine is offline
FRC #0417
DillonMartine is an unknown quantity at this point
Also, For some reason, If you remove the watchdog, the Dongle switch for the DS does not work. When the code for the watchdog is added again, it functions normally.. Strange.
Unread 10-02-2009, 23:49
Just Itinerant
I'll have to try that one. That's good to know. Thanks.
pic: Always Come Prepared A_Reed Extra Discussion 6 26-03-2007 14:22
WE LOVE YOU ALWAYS BrendaB Thanks and/or Congrats 0 29-02-2004 08:19
pic: Working Hard, As Always CD47-Bot Extra Discussion 4 14-04-2003 09:07
always good teams nuggetsyl General Forum 1 10-01-2003 22:20
HELP! is always available at NATs archiver 2001 0 24-06-2002 03:04
