cRIO v7 fails
We connected the cRIO and other components, and ran the benchtop test with no errors. The joysticks control the motors as expected. Then we updated the cRIO firmware with FRC_2009_v7.zip, following section 5.1.2 of the Control System manual, and selecting the LabView option and our IP address. Apparently OK; all messages showed as described in the manual. Now, at power on, the LEDs on the Jaguars blink, and a green LED on the digital sidecar blinks. I loaded LabView on our laptop and selected the RT cRIO Target, Basic Robot Main vi. I selected the Run option, which apparently copied the program to the cRIO OK. The Jaguar LEDs and sidecar LED continued to blink, and we found no response to the joysticks.
What am I doing wrong? |
Re: cRIO v7 fails
Re: cRIO v7 fails
You will also need to restart the cRIO (by removing power, waiting a couple seconds, and re-applying power) to make everything work.
Re: cRIO v7 fails
I updated LabView to the latest configuration. I was unable to update the Driver station; same problem with the USB drive as several other teams reported. I will try other USB drives Tuesday to see if one works.
We recycled cRIO power several times, waiting up to several minutes between. |
Re: cRIO v7 fails
Re: cRIO v7 fails
It is times like these I wish FIRST had an official wiki where people could aggregate knowledge about what works and what doesn't work. Someday...
Re: cRIO v7 fails
Me too! I used a 16GB Kingston DataTraveler. Worked great.
Re: cRIO v7 fails
Did you update the Driver Station firmware as well? If the LCD reads *** OTB *** on the last line, then it's not gonna work with the updated cRIO image.
| cRIO fuse??? 20 or 30? | mynameisbob | Electrical | 12 | 09-01-2009 11:33 |
| Code runs only once, fails on reset | roknjohn | Programming | 7 | 21-02-2005 20:24 |
| Code suddenly fails to initialize | miketwalker | Programming | 11 | 19-02-2005 15:23 |
| Camera fails to output anything on serial lines | steven114 | Electrical | 10 | 18-01-2005 16:12 |
| When all else fails.... | ColleenShaver | Robot Showcase | 5 | 02-02-2003 01:11 |
