Go to Post Andy Baker doesn't go to IRI. IRI comes to Andy Baker. - tim_reiher [more]
Unread 18-01-2009, 16:51
Team2883's Avatar
Team2883 Team2883 is offline
FRC #2883
Team2883 will become famous soon enoughTeam2883 will become famous soon enough
Unhappy Programming into Servo??
We have been having trouble programming servo to our joystick . We have two joysticks and the first one is under "USB1" and is connected to two "joystick: get axis" and one of them is "axis 1" and the other is "axis 2" and the "joystick: get axis" is connected to a "drive: arcade drive". The second joystick we have connected to one "joystick: get axis" and it is an "axis 1" and that is connected to a different "drive: arcade drive" which is connected to an "error in (no error)" box. Our "servo: open box" is on "slot 4" and "pwm 3" and is connected to "servo: get angle" and that has an angle box connected to it and the "servo: get angle" is connected to "servo: set angle". We are in labview. We can't get the "servo: set angle" to connect to anything. We did have it connected to a knob but we deleted it. If you can help us that'd be great, or if you know the number for the 24 hour help line that can assist us that'd be even better. Thankyou!
Unread 18-01-2009, 18:56
The Megan 2207's Avatar
The Megan 2207 The Megan 2207 is offline
FRC #2207 (Prime 329)
Rookie Year: 2007
The Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really nice
Re: Programming into Servo??
Could you post a picture or something? I think I might be able to help but I'm not good with written descriptions. I worked with programming a servo to run off of our joystick, but we only used one. I think that your problem might be using 2 joysticks with arcade drive (are you trying to do tank drive?), but I'm not sure.
Help again with Servo Programming programmr Programming 3 14-02-2008 19:56
Servo Programming Again..... programmr Programming 1 14-02-2008 09:31
How do you get servo numbers into Angle Degrees Cow Bell Solo Programming 3 18-02-2007 12:16
HS-322D servo programming question JimHull Programming 12 10-02-2007 15:14
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
