Go to Post the hardest task this year is the same as every other year: getting the engineers out of the crate so you can close it up and the FedEx guy can haul it away! - KenWittlief [more]
Unread 18-01-2009, 20:18
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Get Button subVI for LabVIEW
Hey all,
I was messing with LabVIEW and found that there was a Joystick Get and a Joystick Get Axis subVI, but no Joystick Get Button. So I made one. Please let me know if there are any errors, I can't test it right away. This is based off of the Joystick's Get.vi that is included with LabVIEW, and it basically serves to eliminate the hassle of using a cluster element selector block. Enjoy, and give feedback please!
P.S. - The "Index" pin is where you'd wire up an enumerated button selector. It's an unsigned byte value, with enumerated items "Button 1" ... "Button 11" and "Invalid". You could also just put in any unsigned integral, though; it should cast down properly. The output is a single boolean, indicating whether the button is pressed or not. Also, keep in mind that Button 1 (the trigger) is enumerated to 0, not 1.
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Labview SubVI return and continue looping skidmarks NI LabVIEW 5 06-01-2009 07:18
Get pixel color (Labview) kamocat NI LabVIEW 4 24-08-2008 02:28
Reset Button for Vex RC's irishninja FIRST Tech Challenge 5 18-06-2006 15:56
Where can I get LabVIEW? Hershey LabView and Data Acquisition 1 21-01-2006 14:38
