Go to Post I'm pretty sure Andrew Baker and Andy Baker are the same person. Then again, Andy may just be holding out on us. - Amanda Morrison [more]
Unread 18-01-2009, 21:18
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
Rookie Year: 2007
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
User code won't download/run-possible causes?
Hoping someone can shed some light on this,
Today we were trying to download our program to the cRio, and were unable to get it either to download or to run(we're not 100% sure where the problem lies). Basically, whenever we use the "deploy" option in FIRST downloader, the progress bar just flashes on the screen, and when we reboot the cRio it does nothing and we get a "no code" warning. The odd thing is that using the "undeploy" option doesn't generate an error, so the cRio thinks it has something loaded. Additionally, we can download the example programs and they work fine. START_ROBOT_CLASS is calling our frcv1 class, and the network connection works fine.
Based on the testing we've done, we think that either
  1. The build specification is wrong, since our program is showing up as "PPC32diab", but the example shows up as "PPC32gnu"
  2. There's some other option that we have to set in order to get the program to run on startup(other than the START_ROBOT_CLASS one)
  3. FIRST downloader doesn't like our binary and is failing silently
Does anyone have any ideas on what might be the most likely, or something else that might be going wrong?
Get yer robot source code here!
[Windriver] Getting error on run: Download Failed JHale C/C++ 4 15-01-2009 07:42
printf causes programs to not run jasonpeinko Programming 6 17-01-2008 18:54
Won't Download! diaperrash89 Programming 4 25-10-2007 23:02
2005 default code won't compile Robby Programming 22 04-02-2005 18:21
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
