Gearbox selection
Hi all,
I'm looking for some planetary-type gearboxes at a reasonable cost, and I'm considering using the 2007-KOP gearboxes. However, I heard that there were some issues with these (stripping gears...???), and then those issues were corrected. Anyone here know the validity of this, and if there's an easy way to identify the corrected version? Also, is the correction something easy to do, with easily available parts (perhaps swap some gears to metal, etc)? Cheers, -Neil. |
Re: Gearbox selection
The problem with the 2007 BaneBots gearboxes was due to an (apparently) brittle carrier plate. Those with a hardened carrier plate can be identified with "-HC" at the end of their part number sticker. That said, plenty of teams used the gearboxes without any issues that year (especially if you support the end of the shaft with a bearing rather than cantilevering the load).
Other planetary gearboxes that fit the CIM include: -Banebots P80 series (http://banebots.com/c/P80A-nnnn-n0n5) (14 reductions between 3:1 and 256:1) -AndyMark GEM500 (http://andymark.biz/am-0270.html) (Each level is a 3.67:1 reduction; you can stack as many levels as you want for more reduction) |
It's barely different. The casing is a little different sized (bigger, I think?), and it's got some more bolts running along it. Otherwise, the Banebots are excellent gearboxes that have now undergone much more testing than their first forte into FIRST.
That being said: my team is using 4 of the Banebots gearboxes. They're small and reliable, and just the PERFECT speed for us. |
Excellent info, thanks. The planetary that banebots is selling now do have the -HC, and I expect to have just a gear on the end, so it sounds like the way to go. I did see/evaluate the P80 and GEM500, but cost is a major issue (plus we'll want to get one spare, so the cost difference multiplies fast).
Craig, are you using single-speed? Cheers, -Neil. |
I am not so sure that you can use the 2007 KOP BaneBots Gearboxes on a legal 2009 FIRST robot, we looked into it but decided that rule R-32 prohibits this course of action.
). The P80s look okay and the GEM 500 does too if you can afford them. |
Yep, my interpretation of R32 is that they also would've had to have been entered in a previous competition, and I found out that we gave them to another team in 2007 (this is my first year with FIRST).
My intention is to purchase from Banebots now, but ,4lex S. if you want to sell yours, let me know. Cheers, -Neil. |
I'd second the suggestion for the BaneBots.
We've never had problems with them in our experiences. great boxes. |
#10
,4lex S., good observation. I have been trying to register on the usfirst forums for a few days now to ask about this to get a definitive answer, but the registration process is failing. Can someone do me a favor and ask this question on those forums, please. Much thanks!
#12
Has anyone received a difinitive answer as to if the BB boxes are allowed this year? One design we're thinking of, it would be very convenient to use our 4 BB boxes.
#13
You don't need a forum ID to look at the Q&A.
http://forums.usfirst.org/showthread.php?t=11555 In other words, they better have the hardened carrier plates. |
#14
Thanks for that clarification, sorry to introduce any confusion into the matter. The annoying thing for us is that we destroyed half our boxes in competition in '07 and all the parts are mixed together in a box... I really have to get my team on top of that Q and A thing. My apologies.
| Offseason gearbox project... maybe this gearbox has helical gears? | Travis Covington | Technical Discussion | 17 | 05-06-2006 11:48 |
| Driver Selection | Mousepad | General Forum | 23 | 26-02-2005 18:36 |
| Motor Selection | vtome | Motors | 2 | 11-01-2003 09:50 |
| DRIVER SELECTION.... | archiver | 2001 | 11 | 24-06-2002 00:02 |
| Driver Selection | archiver | 2000 | 7 | 23-06-2002 22:05 |
