Go to Post We may be changing cheese heads for cheesy poofs, but in the imortal words of Gen. MacArthur "we shall return" (team # 2437) - cdebo [more]
Unread 01-19-2009, 05:22 PM
piedmont piedmont is offline
FRC #3022
piedmont is an unknown quantity at this point
Arcade/Tank Drive Malfunction
This is team 3022, and we are a rookie team. We decided to go with tank drive this year, but after we finished setting up the driver station with the wireless connection, it automatically set up to arcade drive. Also, the arcade drive is faulty in this case. Forward and back move their respected directions, but when we move the first joystick left, it turns clockwise rather than counter clockwise. When we turn it right, it moves backwards. In order to make it turn counterclockwise, we have to turn it back/right.
We want to have it to be tank drive. Can someone help us on how to fix this?
Unread 01-19-2009, 05:28 PM
Hunter1100 Hunter1100 is offline
FRC #1100
Hunter1100 is an unknown quantity at this point
Re: Arcade/Tank Drive Malfunction
If you are using the default code with the attack 3, move the Z axis of the joystick (Its the roller in the back of the joystick, dead center) all the way down to switch to tank drive.
Unread 01-19-2009, 05:37 PM
FRC #3022
thanks, it works. u saved our team
Tank Drive Sauce Programming 1 01-05-2009 06:50 PM
Arcade Drive Anfony VEX 4 11-08-2006 07:46 PM
vex programming arcade drive setting Michael Leicht FIRST Tech Challenge 3 10-17-2005 09:26 PM
Tank Drive Idaman323 Programming 14 02-15-2005 09:01 AM
tank drive Stormhammer Programming 11 01-29-2004 11:08 PM
