Go to Post Many would say it is both gracious and professional to make sure your robot will not damage another team's robot. - 4throck [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 20-01-2009, 11:37
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
FRC Robot Boot-up Deployment (failed to deploy)
I am running the Advanced project in Labview, and cannot set the built code to run at startup.
I am connecting from my PC with the cross-over cable to the cRio.
The build properties:
Information tab
Build Specification name:FRC Robot Boot-up Deployment
Target filename: startup-rtexe
Local destination directory: C:\robot
Target destination directory: c:\ni-rt\startup
Build specificaton description:Advanced 4 motor drive
Robot_main is selected in the Source Files tab.
I have been able to deploy the built executable once about a week ago, but I can no longer deploy code to 'run as Startup'
I am able to run the Robot Main through Labview and everything works great, but I just cannot deploy the newly built application.
IP address of the cRio: 10.10.94.2
IP address of the PC: 10.10.94.6
When I attempt to run as startup, it gives me a warning page saying that some vi's will be refreshed by this procedure, which should be fine since I am replacing code in the cRio.
I then get a list of files that were downloaded to the cRio, along with a failure message (deploy failed). If I scroll up the list, I see the message:
Has anyone seen this error?
Is there a log file somewhere that would tell me why it failed to deploy?
Any help would be appreciated.
97's Ramp Deploy ZZII 527 Robot Showcase 5 28-02-2007 15:18
1583 Ramp Deployment Video NOV8R Robot Showcase 9 11-02-2007 12:09
Ramp deployment a hazard? marc Rules/Strategy 7 11-02-2007 10:54
Team 1345's ramp deploy and robot on top. Arefin Bari Robot Showcase 7 07-02-2007 17:17
