Go to Post 71% efficiency is best efficiency. ;) - Chris is me [more]
Unread 20-01-2009, 19:44
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
question about <G14>
for example: if we have these 3 teams playing as one alliance-
team1, team2, team3 and they got 2x scoring than the other alliance>>
in the next match if we have:
team1, team x , team y played as one alliance -
** is team x, or team y allowed to use 2 super cell ??
** if team 1 played a second match and they were not allowed to use 2 super cell. but the third match they played with team 2 whose match is the second and they are not allowed to use 2 supercell .... so what about team1!!
is it fair that team 1 played the third match without a 2 super cell ??
Unread 20-01-2009, 19:47
mahmosh's Avatar
FRC #1946
Re: question about <G14>
if there is something u didn't understand tell me...
Unread 20-01-2009, 19:54
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Should you get 2x your opponent's score, in your next match your PAYLOAD SPECIALIST will lose 1 ball. If he is at the OUTPOST, he will get 1 less EMPTY CELL. If he is at either FUELING STATION he will only have the opportunity to trade for 1 SUPER CELL.
*Yes. Team1 is also allowed to use a SUPER CELL/EMPTY CELL it's just that their PAYLOAD SPECIALIST gets 1 less SUPER CELL/EMPTY CELL.
**I don't think I understand the question. Do the above clarifications help though?
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 20-01-2009, 20:05
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Each corner payload specialist gets 2 supercells on their rack, each payload specialist in the center outpost gets 4 empty cells on their rack. If a team is down 1 empty/super cell then where ever their payload specialist is will be down 1 cell.
Once a cell (empty, super, or moonrock) is entered into play (entered into the crater) is can be used by any team, of any alliance, and any payload specialist.
So, technically (even though I doubt this would ever happen), a team could be down 1 supercell and their payload specialist could still handle 7 supercells ... 3 from their own alliance (being down by 1 supercell) and 4 from the opposing alliance.
Hope this helps.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 20-01-2009, 20:20
mahmosh's Avatar
FRC #1946
so if the team is down 1 supercell ... and he is in the outpost so the other 2 teams with my alliance can use 4 super cell ... 2 for every payload specialist??
Unread 20-01-2009, 20:27
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
If your team's PS is in the Outpost, and you are down by 1 cell, your alliance can use a total of 3, not counting the other alliance's. Your PS loses 1 empty cell, which then cannot be exchanged for a Super Cell. So you have a maximum of 3 super cells available, not counting your opponent's missed shots.
If, on the other hand, your team's PS is in a Fueling Station, you lose 1 Super Cell and no Empty Cells. You still only have 3 Super Cells, not counting your opponent's missed shots.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 20-01-2009, 20:28
Mad Scientist
AKA: Me
FRC #2040 (DERT)
If your team is down 1 empty/super cell (due to <G14>) and you put your payload specialist in the outpost then he will be down 1 empty cell (4-1=3) as there are no super cells there.
It is still possible to use 4 super cells in this case if you can take one of your opponents empty cells and convert it to a super cell at the corner payload specialist.
___________________
- Tennyson, Ulysses
Unread 20-01-2009, 20:31
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
If a team scored 2x (or 3x) last time, that team will lose 1 (or 2) orbit balls when they play their next match. Which kind of balls it will lose depends on which payload specialist station the team is in. If the other teams in the alliance for that next match did not double (or triple) scores last time, those teams will have their full allocation of balls.
(since 2004)
Unread 20-01-2009, 20:48
mahmosh's Avatar
FRC #1946
THANKS ALOT ... I UNDERSTOOD
that's a good idea
Question about bumbers and stuff about our chassis Cow Bell Solo Rules/Strategy 10 21-01-2009 16:56
A statistical look at G14 Bongle Rules/Strategy 23 19-01-2009 14:08
<G14> Shenanigans? Team1710 Rules/Strategy 123 12-01-2009 12:42
My case against <G14> bduddy General Forum 58 07-01-2009 15:20
Rule G14 KE5WGE Technical Discussion 3 03-01-2009 17:36
