Go to Post You know, sometimes it is really cool to be a geek! - dlavery [more]
Unread 21-01-2009, 09:37
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
smcmahon is an unknown quantity at this point
Question Robot Signal Light
I figured out how to wire the RSL from the diagrams. My question is, what do I graft onto the end of it so that it can plug into the Digital Side Car? I saw someone mentioned "a two pin connector found in the kit". Can anyone explain what this looks like in more detail? I found a few WAGO connectors and stuff, and some jumpers for the servos. Did I miss it?
Unread 21-01-2009, 10:07
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
Rookie Year: 2007
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Re: Robot Signal Light
You might have missed it...we took them out of the original package they were in, but I believe they were in a seperate plastic bag by themselves. It should be a gray wire with a red and white wire coming out of the end attached to a black casing for the pins, similar to a PWM black plug (casing, not sure of the word)
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 21-01-2009, 10:46
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Hmm. I will go down there and look around for that. Thanks!
Unread 21-01-2009, 11:57
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
In this photo of the Control System parts: http://www.chiefdelphi.com/media/img...d504b545_l.jpg
They are the coiled grey cables all the way to the bottom right.
They have 2-pin connectors at either end. Cutting them in half gets us two connections.
Unread 21-01-2009, 12:11
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
I'm not sure if the GDC misinterpreted the question posted here, or if they really want the RSL to use 18 awg wire. If so, the provided wire with 2 pin connector would be much too small.
Unread 21-01-2009, 12:51
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
I was thinking the same thing as Joe. I tried to strip the little red and white wires in that set, and they were too small for the 22 gauge hole. So they must be pretty small.
I was looking at these things on All Electronics. I need to go measure the distance between the pins I guess. Some of these use 18 gauge wire and some use 22 gauge.
http://www.allelectronics.com/index....tem&id=CON-232
http://www.allelectronics.com/index....em&id=CON-230P
http://www.allelectronics.com/index....tem&id=CON-242
Maybe something like that will get the job done? I'm sure not a lot of people put much thought into the signal light yet, but I wanted mess with it, and found I didn't know how to make the wiring connections...
Unread 21-01-2009, 13:30
Just Itinerant
We built our own cable for the signal light with heavier gauge wire and haven't used the ones that came in the KOP.
I don't think that Q&A answered the RSL wiring question, since the RSL is wired to the Digital Sidecar and not a 20amp breaker circuit it's a unique connection. Somewhat on the order of what's the minimum gauge required for the PWM servo wire that comes off the PWM's, DIO, Relays and I2C header pins.
Needs to be asked again I suppose.
Unread 21-01-2009, 14:19
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Mark,
If I may ask... what did you put on the far end of this cable to plug into the sidecar? I was thinking about just a two-pin connector, like the ones I lined above. You feel that is sufficient? Where did you find whatever you grafted onto the end, to accept the two male pins protruding from the side car?
Unread 21-01-2009, 14:23
Just Itinerant
I cut & pasted this out of a team document, so the formatting may be a little strange.
We usually get these supplies from Jameco.
.1” header supplies
For making your own 2 & 3-pin PWM cables, as well as, Driver Station pin connections
Jameco catalog page: http://www.jameco.com/Jameco/catalogs/c291/P64.pdf
50’ 3-color servo wire, 22 gauge
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?jameco_page=42&langId=-1&productId=396279
2-pin Housing – 100812 (as of 1/14/09)
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?jameco_page=42&langId=-1&productId=100812
(Note the photo is generic and not for 2-pins)
3-pin Housing – 157383 (as of 1/14/09)
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?jameco_page=42&langId=-1&productId=157383
(Note the photo is generic and not for 3-pins)
Male pin – 145358 (as of 1/14/09)
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?jameco_page=42&langId=-1&productId=145358
Female pin – 100766 (as of 1/14/09)
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?jameco_page=42&langId=-1&productId=100766
Crimper - 159266
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?jameco_page=42&langId=-1&productId=159266
Unread 21-01-2009, 14:26
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
This might be a little off topic, but the robot signal light has just been uploaded to www.3dcontentcentral.com. So, if you use Solidworks you can now add it to your designs.
http://www.3dcontentcentral.com/Down...d=171&id=13657
Unread 21-01-2009, 17:26
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
The connector used to connect audio from an internal CD to a motherboard is the same as the PWM male end but just 2 wire.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 22-01-2009, 09:13
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Thanks Mark. I ordered a few things from that Jameco website. That's about exactly what I was looking for. Thanks for sharing.
Unread 22-01-2009, 11:08
sircedric4's Avatar
sircedric4 sircedric4 is offline
AKA: Darren
no team (The SS Prometheus)
sircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond reputesircedric4 has a reputation beyond repute
I guess I had my students do this wrong. We just used a regular PWM cable and only plugged in the two wires that were active on that cable. There is plenty of room for one end to hang off the front of the connector on the board.
The LED works correctly but I don't know what the inspectors will say if they even catch it. I'll see what it takes to use the grey wires before having them fix something that works already.
Unread 22-01-2009, 11:11
Just Itinerant
I think that's a simple and valid solution.
  #15   Spotlight this post!
Unread 23-01-2009, 09:44
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
http://decibel.ni.com/content/docs/DOC-3120
For anyone interested, there is a new doc on NI's website that describes the various RSL states and their meaning.
Russ
Signal Light DustinB_3 Electrical 10 21-02-2007 13:10
Controller Out to Signal Light Failed franzulrich Electrical 1 20-02-2007 11:38
Whats the Robot Signal light for? steve d Electrical 12 20-02-2007 08:29
Robot signal light 11Mort11 Regional Competitions 11 19-02-2007 10:46
Signal light trouble-shooting customh Electrical 33 17-02-2007 16:43
