Go to Post Point is, there is no definite answer. This is FIRST, Whatever works well with your team is the best. - NelsonMichael [more]
Unread 21-01-2009, 10:23
whswrestler189 whswrestler189 is offline
FRC #1742
whswrestler189 is an unknown quantity at this point
Trouble With Autonomous Camera Tracking
For the past few days our programming team has tried to have the robot follow a target. We took the two color servo example from NI.com and instead of using the Panning servo we use that value output to run our Drive motors. We succeeded in having the robot turn left and right but it did not stop when the VT was in the center of vision again. It continues to turn left until it breaches the threshold set to turn right. In other words it keeps turning until it goes too far then turns the opposite direction until it goes too far. We are trying to set a "zero point" were if the values given are between 70-100 both drive motors are stopped. Unfortunately no attempts have been successful. Any ideas or help would be greatly appreciated.
Programming of Team 1742 - Shockwave
Trouble with Autonomous popnbrown Programming 15 27-02-2007 20:48
How should we call camera tracking functions during autonomous mode? SHerpich Programming 1 15-02-2006 18:33
Moving robot while tracking with camera questions... Steve Orr Programming 6 02-02-2006 22:24
Having trouble with your camera mount? Chriszuma Programming 7 01-02-2005 22:12
trouble with beacon tracking code [53] opticruzer Programming 9 27-01-2004 12:19
