Go to Post When you build a practice robot, you're literally buying time. - sanddrag [more]
Unread 21-01-2009, 11:36
agmlego's Avatar
agmlego agmlego is offline
Jack-of-all-trades
AKA: Andrew Meyer
FRC #0857 (Superior Roboworks)
agmlego is an unknown quantity at this point
Send a message via ICQ to agmlego Send a message via AIM to agmlego Send a message via MSN to agmlego Send a message via Yahoo to agmlego
Photoswitch
Our team would like to put a couple photoswitches across our cell collector opening, to detect the cells. I have been looking around for the AB photoswitch that was included in the KoP a few years back, but I cannot find it. Does anyone know what model it was, or can recommend a better photoswitch for this purpose? Thanks much!
"I can guarantee that if it breaks today, it will be something that has never broken before"
--Arthur C. Clarke, The Trigger
Unread 21-01-2009, 11:45
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Re: Photoswitch
Ill be honest here, I don't remember any photoswitch being provided in the KOP in previous years. But, if it was you should be able to find it in an old KOP checklist.
http://usfirst.org/community/frc/content.aspx?id=4094
Unread 21-01-2009, 11:59
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Re: Photoswitch
Do you mean the Banner sensors? Those were pretty simple yes/no sensors that were light based.
On short notice I could only find the 2003 spec sheet for them, I can't remember if they were in the KoP more recently.
http://www2.usfirst.org/2003comp/Spe...nersensors.pdf
Unread 21-01-2009, 12:06
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Photoswitch
I remember there being photogates in the 2006 KOP, but not much about them.
Unread 21-01-2009, 14:34
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Photoswitch
I can find no reference to a photo device after 2003 as Eric has shown above. These were actually very interesting little devices capable of looking for reflections of their own source and they were adjustable.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 21-01-2009, 16:20
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
Re: Photoswitch
The Allen Bradley Photo Switch was in the 2006 KOP. It was indeed a dandy little pair of devices. Hard to find, though. Anyway, it's on page 27 of this document http://www2.usfirst.org/2006comp/Man...obot_Rev_F.pdf helpfully called Receiver and Source. If you find a place with them in stock, I'd love to know about it!
Unread 21-01-2009, 16:35
Ted Weisse's Avatar
Ted Weisse Ted Weisse is offline
AKA: xMentor/Inspector/Referee
Ted Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of lightTed Weisse is a glorious beacon of light
Re: Photoswitch
It depends on how much you want to spend. For about $80-$100 you can use others such as Banner Engineering.
http://www.bannerengineering.com/en-...ectric-Sensors
Retro-reflective across an opening or defused up close if used in a chute. What out for the web of the ball. I have not tested any of these with the game pieces but have used their sensors for many applications.
If I am not for myself, who will be for me?
If I am not for others, what am I?
And if not now, when?
-Rabbi Hillel
Jewish scholar & theologian (30 BC - 9 AD)
Unread 21-01-2009, 18:30
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: Photoswitch
We just tried this last night with a sharp IR sensor . The ones we are using are the analog ones so they give and actual distance. Look at the digikey website- http://search.digikey.com/scripts/Dk...4001e,fffc01a9
One note about these. You need an odd cable. Spark fun electronics also sells them and they have a cable for it. If there is a long run of cable from the Crio to the sensor, a 10 uf or greater cap is recommended across +- for a stable signal. For a short cable you might get away with out it. Trying out new sensors with labview is a joy this year. There are allot of filter VI that can clean this up and ones that can take the analog input and give trigger outputs.
Unread 22-01-2009, 12:06
agmlego's Avatar
Jack-of-all-trades
AKA: Andrew Meyer
Re: Photoswitch
Thanks for all the replies. The one Dale posted is exactly what I was looking for. I will post later if I find any in stock anywhere.
How do you program the Photoswitch nekng Programming 2 27-11-2006 13:41
Photoswitch ATK Electrical 1 18-02-2006 20:37
Photoswitch coding magical hands Programming 0 17-01-2006 21:20
What is Photoswitch? magical hands Programming 1 17-01-2006 16:15
