Thread Tools |
Rating:
Display Modes |
Need help with Axis 206 Power Adapter
i need the Network Adapter 2-Lead PN# SA106A-0512-6 and i dont know where to find it, nothing on the search engines and does anyone know if i can replace it with something else from radio shack, i dont have the specs that are written on the adapter because i dont have it.
thank you |
Re: Need help with Axis 206 Power Adapter
Output specs are 5.1v, 2amps
center positive on the connector, but I can't remember the barrel type. The two adaptors in the KOP weren't enough? ![]() http://www.axis.com/products/cam_acc...supp/index.htm Mains adaptor PS-H part # 5500-331 Should be able to find a close match at Radio Shack. Goggle it and you get a bunch of hits like this ($39): http://www.moonblinkwifi.com/pd-powe...h--5500331.cfm Last edited by Mark McLeod : 21-01-2009 at 20:15. |
| Programing servo in Axis camera 206 | frcchile | NI LabVIEW | 6 | 18-01-2009 08:53 |
| ehh... We need a ttl-232 adapter | pbhead | Technical Discussion | 4 | 19-07-2007 23:31 |
| need help with power dist block & maxi bkr | steve d | Electrical | 4 | 07-02-2007 18:07 |
| hey need some help with writing a code please help me here | magical hands | Programming | 9 | 01-01-2004 21:46 |
| I need some bright ideas. What to do with a POWER DRILL.... | archiver | 2000 | 5 | 23-06-2002 23:14 |
