Go to Post I would not want the task of devising a system that 50,000 very smart people try to outwit. - texarkana [more]
Unread 21-01-2009, 20:48
Lesman's Avatar
Lesman Lesman is offline
FRC #1014 (Bad Robot)
Lesman will become famous soon enough
Get a gear on the Fisher Price
Hi, our team decided to get a banebots gearbox for our fisher price and have had some trouble using it. After a long battle with the gear that is already attached we managed to break it off (chisel, heat, dremel, pliers, hammer). The shaft was still straight and it was still workig. Sadly while attempting to get the new gear on we bend the shaft running through the motor, effectively ruining it. We placed the motor in a clamp, put the gear on the end and pressed them together, we tried to keep everything aligned as much as possible but that did not work. Does anybody have a suggestion? We would really like to use these gearboxes. We do not have any sort of press (arbor or otherwise) though we could get a small one (1 ton press at sears = $88) if we must. Thanks!
Unread 21-01-2009, 21:36
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: Get a gear on the Fisher Price
1. NEVER EVER try and press on a gear without supporting the shaft itself (I drilled a tiny pocked into a small block of metal and used that on the back end of the shaft). The bearings in the fischer price aren't meant to take loads in that direction.
2. Make sure that the bore on your gear is right. I forget the exact size (I'm fairly positive that it's a 30 or a 32, measure the smooth part of the shaft to make sure). The splines on the shaft work real well for pressing on a gear.
With the right bore on the gear and the shaft supported, we were able to tap on the gear with a medium sized hammer. You'll want a socket or some sort of spacer to get the gear past the tip of the shaft.
EDIT: Our application was for a custom gearbox but it worked beautifully and no slippage occured. Use some medium-high strength loctite on your shaft.
-Vivek
"we don't build robots, we build people"
Unread 21-01-2009, 21:41
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
There is a thread from 2008 on various methods to do this. I would search for it.
2001-2004: Team 100
2006-Present: Team 254
Unread 21-01-2009, 22:11
Lesman's Avatar
-Vivek
We did have is supported, one side of the clamp was pressing against the back end of the shaft. And the gearbox was made specifically for fisher price motors. I think we may have just been a little rough with the motor.
Unread 21-01-2009, 22:18
vivek16's Avatar
AKA: vivek
Rookie Year: 2007
I would re-check the bore on your gear. Even if you are 110 percent positive, just do it. Holes get mis drilled sometimes. I know that I broke 4 motors in the summer trying to press a misdrilled gear onto a fp motor. Very painful experience.
good luck, Vivek
Unread 21-01-2009, 23:36
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
good luck, Vivek
Viv is right, the BB540 shaft is smaller than the FP. If you try to press that on you will have a disaster.
An arbor press is the best and safest way. See if a local machine shop will let you use theirs, or most good auto repair shops will have one too.
If you decide to purchase one you wont regret it.
Unread 22-01-2009, 00:25
DonRotolo's Avatar
Back to humble
FRC #0832
For an arbor press, check with Harbor Freight.
Unread 22-01-2009, 00:31
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If the fit of the gear is right, then using a hammer and some type of round driver, and properly supporting the rear end of the motor shaft, should work fine. A press is nice, but should not be necessary.
Also the FP gear is sintered, isn't it? a good whack of a big hammer on a chold chisel, placed between gear teeth, with the gear laying on a solid metal surface, should split it easily.
Unread 22-01-2009, 02:03
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Someone really needs to make a video of this and upload it. Many teams have pm'd me the same question over the years. Or could anyone take some pics of this in action and I could upload it. Thanks to anyone that would like to do it.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 22-01-2009, 13:31
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
From the original bane bots thread back in 2006
http://www.chiefdelphi.com/forums/sh...ad.php?t=41335
Check out post #18 where I discuss how to install the gear onto the shaft. the whole thread is a good read on these gearboxes. Read from #18 on at least as it discusses a few changes if you are using some gearboxes.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 22-01-2009, 17:47
Lesman's Avatar
Alright, thanks for all of the help! I'll try to videotape it and put it up on youtube. If it goes well...Then again, if not, it can be a "what not to do" video.
AM Planetary Gearbox (removing the fisher price gear/buying one without a gear) Ice Berg General Forum 10 04-02-2009 15:43
fisher price gear railerobotics Motors 2 14-01-2009 17:20
fisher-price pinion gear bill mc gowan Motors 6 06-03-2006 11:14
Specs on the gear of the fisher price motor archiver 2000 0 23-06-2002 23:23
FISHER PRICE GEAR BOXES archiver 1999 2 23-06-2002 22:07
