Go to Post No disclaimer on earth lets you disassociate yourself with your team or what you represent because you want to say something not particularly nice, but lets you be associated again when you want to say something to encourage others, etc. - Amanda Morrison [more]
Unread 22-01-2009, 11:58
rzienta rzienta is offline
FRC #2866
rzienta is an unknown quantity at this point
Problem with Controller
Couldn't find anything in search.
The "Select" button on our controller does not spring back. When pushed, it stays down.
We are a rookie team. HELP!
Unread 22-01-2009, 12:05
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: Problem with Controller
Opening the device voids its warrenty so I would recommend contacting FIRST before you do anything.
Since I just see FIRST's name on the Driver Station, try contacting them by phone or make a post on the FRC forum: http://forums.usfirst.org/forumdisplay.php?f=1002
Hopefully you get a speedy reply.
Amperage Robotics Team 1225
Site under-going revamp. :/
[FTC]: Problem with two controller setup in Labview wilsonmw04 FIRST Tech Challenge 2 11-11-2008 19:58
problem with speed controller gaby1367 Electrical 11 14-05-2007 22:16
Problem with the program downloaded to the controller itsme Programming 9 14-01-2007 12:12
I have a BIG problem with my controller, need help. razer Control System 7 12-01-2007 06:21
Problem with the 2005 controller Guy_E Programming 10 18-12-2006 01:38
