Go to Post Never underestimate people's ability to underestimate. - Ginger Power [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 22-01-2009, 14:14
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
KoP Quadrature Encoders
Greetings from 2603; just a few quick questions. I searched and could not find all the information I need; if I missed it, I apologize; I don't want to waste anyone's time.
We have our KoP encoders mounted on our prototype chassis using AndyMark ToughBoxes and AndyMark encoder mounts. Since these were in the KoP, I was expecting there would be some sort of documentation about the sensors; I have not been able to find this -- only the documentation for the accelerometer and gyro -- not even on the OEM's page for the encoders, so I cannot find the number of pulses per revolution. The OEM's page says that it will have 400-1440 PPR; is there anything more specific, or a way to set this? Additionally, I see in the documentation for the Encoder class for C++ that we can use the pulse width in microseconds; is this information a viable alternative to the number of pulses to determine RPM, or, what is it useful for?
Thank you for your time!
I cut myself shaving with Occam's razor.
Help Programming a Quadrature Encoder programmr Programming 17 20-06-2008 10:40
Encoders..... manderson5192 Programming 4 07-02-2008 10:10
Quadrature shaft encoder source billbo911 Kit & Additional Hardware 7 06-01-2008 19:52
Turning a gear-tooth sensor into a quadrature output encoder Jared Russell Programming 4 18-01-2006 22:19
Quadrature encoders Max Lobovsky Control System 7 14-03-2004 18:25
