Go to Post A chop saw may cut aluminum, a knife can also be used to eat ice cream. - fox46 [more]
Unread 22-01-2009, 16:53
nate15810's Avatar
nate15810 nate15810 is offline
World's Most Clueless Programmer
FTC #0154 (154 Renegade)
Rookie Year: 2007
nate15810 is an unknown quantity at this point
[FTC]: Top Hat coding problem
ok yet another coding problem for me.
this is my problem:
Code:
if (joystick.joy2_TopHat = 0)
      servo[ServoB] = 20;
    else
      servo[ServoB] = 255;
this won't work, nor will
Code:
if (joy2_TopHat = 0)
i need the top hat button to activate servos, but nothing is working
contacted patrick, but it still doesn't work...he's studying and i don't want to bother him anymore haha
Unread 22-01-2009, 17:23
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Re: [FTC]: Top Hat coding problem
Your problem is just an syntax error.
The sign "=" is an assignment operator where the sign "==" is the comparison operator. So you would have to do...
if(joystick.joy2_TopHat == 0)
code goes here
1648: 2013-2014
5283: 2015
Unread 22-01-2009, 18:03
nate15810's Avatar
Rookie Year: 2007
thanks it works
Unread 23-01-2009, 18:20
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
Originally Posted by nate15810 View Post
thanks it works
Ask me how long it took me to remember that "or" in C is really "||". Some of us haven't programmed in C in a L-O-N-G time.
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 23-01-2009, 19:47
Sunny
Rookie Year: 2007
I have never programmed in C before. I picked up the basic syntax from java and I just needed to learn the functions for this year.
The syntax is amazingly similar.
1648: 2013-2014
5283: 2015
Unread 23-01-2009, 22:33
The secret of software development is that structures replicate a lot across languages, but the language programmers randomly change syntax. You will eventually find yourself thinking, "OK, how do I do recursive functions in this <blank blank> language." You know the structures are there somewhere -- you just need to decipher how to make it work in THIS language. Using "&&" instead of "and," for example, is just an arbitrary choice from the dim past. YMMV.
top hat Loki1989 Programming 3 20-11-2007 21:24
pneumatics coding problem (or technical) wildabyss Programming 2 22-02-2005 22:16
pneumatics coding problem (or technical) wildabyss Pneumatics 2 22-02-2005 22:16
coding problem!! HELP! wildabyss Programming 7 21-02-2005 21:48
Pneumatic Coding Problem lasoaaro Pneumatics 11 18-02-2005 12:11
