Go to Post May your shirts be full of buttons, yours inspiration be plentiful, and your error messages be few. - Barry Bonzack [more]
Unread 22-01-2009, 17:20
ericbarch's Avatar
ericbarch ericbarch is offline
221 Robotic Systems Engineer
FRC #0027 (Team Rush)
Rookie Year: 2007
ericbarch is a jewel in the roughericbarch is a jewel in the roughericbarch is a jewel in the roughericbarch is a jewel in the rough
Send a message via AIM to ericbarch
Webcam RGB Calibration VI
Just finished this VI for our team...figured it would be of use to other teams. It's somewhat similar to the CMU2 VI that has been used in past years.
All you need to do is run the VI and it will ask you to load a webcam image in.
If you have a webcam loop setup in your main project you can just send the webcam image to a display and from there you can save frames captured from the webcam. Input these images into this calibration VI and then you can get your RGB color values set dead on.
Enjoy.
Eric Barch
221 Robotic Systems
Controls Engineer
http://team221.com
Light RGB Sensor knine143 Programming 6 06-05-2008 21:21
Pre-programmed RGB values bush Programming 3 28-01-2006 22:13
RGB colors in camera.h X-Istence Programming 5 11-01-2006 21:59
WebCam archiver 2001 0 23-06-2002 23:00
WebCam archiver 2001 2 23-06-2002 22:55
