Move Gizmo far Away from Object
I am using physique to constrain several objects to a biped. I want one of these objects to be able to rotate without moving the biped. After applying physique, the rotate gizmo stays at the spot where the biped was in figure mode, causing the object to rotate around the axis I want. Any way to fix this? The only thing I've tried is XForm, but I would have to move the gizmo with the object throughout the animation(I think).
| Off-Season Challenge - I Like to Move It, Move It! | Kevin Thorp | 3D Animation and Competition | 11 | 03-11-2008 16:04 |
| 1346 Far from Finished... | dtengineering | Robot Showcase | 4 | 09-02-2008 21:30 |
| Cmaera semi-running away from light | amateurrobotguy | Programming | 3 | 04-02-2006 17:23 |
| GETTING AWAY FROM THOSE WALLS? | J15.5h | General Forum | 6 | 10-12-2004 16:13 |
| Ucf so soon...but yet sooo far away | Ryan Albright | Regional Competitions | 20 | 23-03-2003 21:19 |
