OK so if you read through the rules you would notice that it says that all wires except copper wires but if you notice, the PMW wires are aluminum so the big question is are these legal?
Re: Wires Legal?
PWM wires are explicitly allowed in various places (say, <R43>, <R54>, and the big one, <R62>). Are you sure they're aluminum?
Re: Wires Legal?
Could be tin plated copper? Hint: if you can solder them, they're not aluminum
Re: Wires Legal?
Aluminum wire is not available in #24 except by special order and it would be very expensive. As Jim has mentioned above, the wire is tin plated copper. The tin is the shiny silver color. If you scrape the wire with a knife, the copper will be revealed.
| Labview Wires | Kahn! | NI LabVIEW | 3 | 19-01-2009 18:31 |
| Sensor Wires | Pneumaticsman | Electrical | 2 | 12-02-2008 07:21 |
| Wires! | Thunder360 | General Forum | 3 | 20-01-2003 20:56 |
| Solenoid Wires | archiver | 2001 | 2 | 24-06-2002 00:56 |
| PWM Wires | Anton Abaya | Technical Discussion | 9 | 14-02-2002 13:59 |
