Go to Post I had a life before FIRST - I just can't remember what it was. - Tom Ore [more]
Unread 23-01-2009, 14:35
FRC1672's Avatar
FRC1672 FRC1672 is offline
Team 1672
FRC #1672 (Mahwah Robo T-Birds)
FRC1672 is on a distinguished road
Issue with DS DigitalOutput
We were testing our digital output and used the set method from DigitalOutput.ccp
Code:
* Set the value of a digital output.
* Set the value of a digital output to either one (true) or zero (false).
void DigitalOutput::Set(UINT32 value)
m_module->SetDIO(m_channel, value);
we used:
set(0)
and set(1)
both gave us issues while building and compiling.
Code:
* Create an instance of a digital output.
* Create an instance of a digital output given a slot and channel.
DigitalOutput:igitalOutput(UINT32 slot, UINT32 channel)
InitDigitalOutput(slot, channel);
I believe our issue was with creating DigitalOutput object. Which slot and channel should we enter to reference?
Issue with Color Tracking Example (C/C++) and with Counters, Encoders, and Ultrasonic BradAMiller Programming 3 19-01-2009 21:24
Interrupt issue with new code EHaskins Programming 6 05-01-2008 00:27
A small issue with our Mecanums AGWSPilot Technical Discussion 15 18-03-2007 02:11
Issue with CMUCam2 Demo application Bio LabView and Data Acquisition 12 21-01-2006 16:08
