Connections to Driver Station
I'm trying to hook up LED's and switches to the input and output of the driver station. When we send the signal to input it gives us a pulse. Any solutions?
Re: Connections to Driver Station
What "signal" are you sending, and where are you seeing the "pulse"?
Remember that the Driver Station inputs don't have a pullup (or pulldown) resistor. You can't just connect a switch to ground (or to +5) and have it work. The input won't work reliably if left floating. You need to either switch it between ground and +5, or attach a resistor (10k or so) to +5 and use a switch to ground. |
| Dead Driver Station? | tdeprince | FRC Control System | 3 | 12-02-2009 12:14 |
| Driver Station Login | Mr-Shutter | FRC Control System | 2 | 12-01-2009 23:36 |
| 2nd Driver Station | bcharbonneau | General Forum | 2 | 09-01-2009 14:19 |
| Driver Station Help.. | 1708xMr.Roboto | FRC Control System | 8 | 22-12-2008 15:24 |
| Driver Station Setup?? | Team 1708 Dave | Programming | 9 | 19-12-2008 23:09 |
