Go to Post As much as you may want the ChiefDelphi community to see your argument, we may not want to see yours. - Amanda Morrison [more]
Unread 23-01-2009, 17:36
the_waterboy the_waterboy is offline
FRC #1095
the_waterboy is an unknown quantity at this point
Color template not loading?
We are trying to use the camera to track the pink flag, just as a test of our camera's tracking ability. We went through NI Vision Assistant and created a script to locate the color pink in an image. We tested it in Vision Assistant using different images and it successfully finds pink. When we try to use the code on our Robot Project, using the sub-VI created by Vision Assistant, we noticed that the program is not loading the template. We noticed this by setting up a probe at the wire coming in for the template and receiving a blank screen. Is anyone else having this problem, or know how to fix it?
So what if I'm crazy?
Invalid color template image? hellochar NI LabVIEW 3 18-01-2009 17:05
[OCCRA]: Template iwanttodunk OCCRA Programming 14 29-10-2008 21:02
Does the Trackball Color Match your team Color??? ZInventor Kit & Additional Hardware 14 07-03-2008 20:09
Template Project Astronouth7303 Programming 10 30-05-2004 20:05
Pictures not loading sanddrag CD Forum Support 32 11-10-2002 01:55
