Go to Post We can still do better, even if we've come a long way. - cadandcookies [more]
Unread 23-01-2009, 20:39
agough's Avatar
agough agough is offline
FRC #0234 (Cyber Blue)
agough is an unknown quantity at this point
Exclamation Catastrophic error
I am testing sending outputs from c++ to dashboard(if you could help with that also I would appreciate it.) When I #include "WPILib.h" it says it cannot open target file "WPILib.h". the odd thing is that this has not happened before and we have other code(not involved with these) that uses it successfully. Could you please either tell me where it needs to be to successfully reference it or what has gone wrong in the code(I am pretty sure that it is something obvious and I am not seeing it).
File Type: h Dashboard.h (134 Bytes, 54 views)
LebView Error -- Error 1055 occured at Property Node in FRC Create Project.vi->FRC Wi RMS11 Programming 8 08-12-2008 18:20
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
