Go to Post Mentors are here to guide and explain not to decide and do. - Fe_Will [more]
Go Back   Chief Delphi > Technical > CAD > Pro ENGINEER / Creo
Unread 24-01-2009, 09:38
ferc ferc is offline
ferc is an unknown quantity at this point
Pro-E techniques
All the techniques and ideas used in PRO-E can be discussed here
Unread 24-01-2009, 09:41
Smile Re: Pro-E techniques
Hi guys!
Can anyone suggest me a way to change dimension of assembled parts and regenerating it to the new dimensions?
For Example - How to change length of channel after forming the basic chassis assembly and regenerating it to the new dimension
Unread 24-01-2009, 09:48
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
in the assembly, you can pick an individual object by right clicking and "activating" it. This will gray out everything else and bring up your part tools. If you then right click on it and say "edit" you should see the major constraining dimensions. changing them and then activating the top assembly should bring you back and everything should auto regenerate. If for some reason it doesn't you can regenerate by clicking the icon on the top bar with the 3 green boxes and circular blue arrow.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 24-01-2009, 12:59
Thanks for your help!
Can you tell me how to assemble the chain assembly onto the wheel sprokets and toughbox sprocket?
Hope to hear from you soon!
Unread 08-02-2009, 11:07
PTC_FRC PTC_FRC is offline
PTC_FRC is on a distinguished road
Hi Murthy,
You can create a sketched curve that goes around the two sprockets, much like the chain would do when assembled.
You would use this curve to assemble the chain to the assembly. The first link would constraint to the curve using a planar joint. The other links would be assembled via pin joint or another mechanism joint.
I have attached a short video of how a chanin can move on a curve and the Pro/E models.
Take a look and give it a try. Let me know if you need help.
Thanks,
Mark
Unread 13-11-2009, 20:50
Hello Mark !
I tried doing the curve for the sprocket.but I'm still unable to assemble the first link of chain to it.Can you guide me through any step by step tutorial or suggest and web resource that can help me do this task ?.
Waiting to hear from you !
Thanks,
Murthy
Unread 10-12-2009, 17:40
rachakate's Avatar
rachakate rachakate is offline
Life's Good
AKA: Kate Leipold
FRC #0340 (Greater Rochester Robotics)
Rookie Year: 1997
rachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud of
Send a message via AIM to rachakate Send a message via Yahoo to rachakate
Greg is right on, but another option is to change the select type in the bottom right corner from Smart to Feature. When you double click on a feature now, the dimensions will show up allowing you to change as mentioned above!
Unread 14-12-2009, 17:03
Hi there !
I tried assembling the chain members as per the instructions.Since i have a longer curve it really takes a whole lot of time to regenerate.I also wonder if we have to constrain all the members of chain with a slot mechanism (each) to the curve ?.
Or is it enough to just constraint the first member of the chain. My model freezes up due to large number of members each having 2 pins joints ( to connect to other members) and 2 datum points per member being constrained to the curve through slot mechanism.
Thanks,
Murthy
Whats your opinion, Pro-life or Pro-Choice? efoote868 Chit-Chat 5 28-09-2007 10:11
Best/Strangest Defense Techniques Stephi Rae Rules/Strategy 40 11-04-2007 00:23
techniques to fasten PVC Pipe to a metal rod? 1166 Technical Discussion 14 19-02-2004 12:21
Discussion of techniques riley_ag 3D Animation and Competition 11 21-12-2002 17:05
Programming Techniques archiver 2001 1 24-06-2002 03:58
