Go to Post Because nothing says safety like carrying a 150lb robot across a field covered in golf balls. - Kevin Sevcik [more]
Unread 24-01-2009, 10:20
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Rookie Year: 2007
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Question can we use 2 batteries?
The question was brought up last night if we can use 2 batteries on our robot? is that considered illegal because you would have more power than the other robots or not because either way you're still only going to be running in for only 2 minutes and 15 seconds.
Thanks
Pneumaticsman
be prepared for the unexpected
Unread 24-01-2009, 10:24
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: can we use 2 batteries?
Only one battery may be used at one time. With 2 batteries in serial, you'll be getting twice the voltage (clearly an advantage although it may fry your controls). With them in parallel you get twice the current. Thats an advantage too.
If one of your batteries is for ballast and is not actually acting as a battery, I believe it is allowed.
"we don't build robots, we build people"
Unread 24-01-2009, 10:27
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
No - you cannot use extra batteries for ballast. It doesn't matter what you're doing with the batteries but only 1 is allowed so you'd better use it for power.
Russ
Unread 24-01-2009, 10:28
AKA: Mitch guzman
Rookie Year: 2007
Ok thank you I just needed some clarification on that. I suppose it's a good thing we can use it as a ballast though cause we're gonna need the weight this year, we're buildin a pretty light bot this year
Unread 24-01-2009, 10:30
AKA: Mitch guzman
Rookie Year: 2007
Dang it now I read Russ Beavis' post that said you can't even use it as a ballast sad day
Unread 24-01-2009, 10:33
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We have a box of pennies at home that weighs 27 lbs....but, how to secure them?
Unread 24-01-2009, 10:38
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Last year in the finals at GLR, Mr. Smith from Truck Town lent 1646 a vice grip that we attached to the robot to offset the weight we lost without our arm.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 24-01-2009, 10:45
Rick TYler Rick TYler is offline
A VEX GUy WIth A STicky SHift KEy
VRC #0010 (Exothermic Robotics)
Rick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond reputeRick TYler has a reputation beyond repute
In a gallon milk jug full of polyester casting resin?
Exothermic Robotics Club, Venturing Crew 2036
VRC 10A, 10B, 10D, 10Q, 10V, 10X, 10Z, and 575
Unread 24-01-2009, 11:21
gorillamonky gorillamonky is offline
FRC #0696
gorillamonky is an unknown quantity at this point
wouldn't that render the pennies unusable?
ps, if they where shaking around, that would be really loud
it wasn't like that when we shipped it
Unread 24-01-2009, 11:39
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
From Section 8 Rev E
<R01>
Energy used by FIRST Robotics Competition ROBOTS, (i.e., stored at the start of a MATCH), shall come only from the following sources:
A.
Electrical energy derived from the onboard 12V battery.
Please remember that anything used for ballast must be securely mounted to the robot frame. The intent as with any object on the robot is to provide the maximum safety for the participants including judges, refs, field reset people and other volunteers near the robot.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 24-01-2009, 14:43
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
388 has used actual gym weights bolted to the frame, and team 116 has a 27lb (I believe) block of lead.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 25-01-2009, 20:32
Unsung FIRST Hero
Rookie Year: 1996
Please remember that lead has some nasty properties. If used, it should be sealed in some fashion, paint works well. Teams using lead ballast in the past were required to complete this step to prevent contamination. Please remember to protect team members when working with this substance as it is prepared for a firm mounting on your robot.
Al
WB9UVJ
www.wildstang.org
Unread 25-01-2009, 20:37
MrForbes's Avatar
AKA: Jim
If we need ballast this year (current robot weight is 106) we were considering cutting up some 16 gage sheet steel, and screwing it to the bottom of the robot. It would be several pieces so weight could be adjusted easily if needed.
Can We use fiberglass? hunter7 Rules/Strategy 2 16-02-2007 17:33
How many extra batteries should you bring, and where can you buy more? haverfordfords Electrical 6 08-02-2005 22:01
can we use? Allie Kit & Additional Hardware 5 13-02-2002 15:54
Can we use? Team537 General Forum 2 29-01-2002 16:49
Can we use Maya? Suneet 3D Animation and Competition 4 08-01-2002 14:44
