Go to Post It's easy to get so caught up in the intensity of build that we forget we need some down time to recharge and get a fresh head. Taking a day off will only happen if you make it a priority as important as any other team meeting. Long hours do not equate to productive hours. - Greg Hainsworth [more]
Unread 24-01-2009, 10:36
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Rookie Year: 2007
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Question Converting LabView to C/C++?
does anyone know if there is a way to convert LabView code into C or C++ code? I know that you can add in your own custom code from the C/C++ language using the code interface node but I was wondering if there is a way to convert an Entire LabView project into C or C++
Thanks,
Pneumaticsman
be prepared for the unexpected
Unread 24-01-2009, 10:58
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Re: Converting LabView to C/C++?
The LabVIEW Embedded module can compile LabVIEW code into C++, but only for Blackfin, ARM, and a handful of other microprocessors and microcontrollers (eg not the cRIO).
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 24-01-2009, 10:59
While a person can read LV code and translate it to C, C++, or other languages, there is no automated way to do that. LV compiles directly to machine code for the target you are going to execute on, just like a C compiler does.
Greg McKaskle
Unread 24-01-2009, 11:02
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
I only know enough to be dangerous so...
No - there is no way with the LabVIEW FRC version BUT NI's LabVIEW Embedded tools are indeed designed to create C code from LabVIEW code. LabVIEW Embedded can then "finish the job" and port that code to specific processors. Using those tools, you do have access to the LabVIEW-generated C code. I've seen demonstrations but never used the program. It looks like a LOT of work to get it configured and running but, in the end, you can let the systems-type folks program in LabVIEW and then let the hard-core embedded SW folks "wrap it up".
http://www.ni.com/labview/microprocessor_sdk.htm
Russ
Unread 24-01-2009, 11:05
The LV embedded tools will indeed be able to generate C code for a subset of your code, but since they don't know how to map WPI and other crucial libraries, I'm afraid this will be a goose chase.
Greg McKaskle
Unread 24-01-2009, 11:06
I recently purchased a LabVIEW for ARM eval kit and am very anxious to try it out. I would love to see teams using such tools for programming Jaguars in 2010.
Russ
Converting Data EasyC charlie1218 Programming 4 15-01-2008 21:48
Converting .wmv Jay W. IT / Communications 6 04-05-2005 15:43
Format converting roberthan 3D Animation and Competition 7 16-05-2004 13:42
Converting CAD!? Tton 3D Animation and Competition 3 25-03-2003 17:29
Converting Files Hailfire Programming 9 28-12-2002 18:59
