Bumper Height
Hey everyone,
How high do the bumpers have to be from the ground? We looked thrugh the rule book, asked our rulesmaster, but we couldn't find the answer. |
Re: Bumper Height
From 8.2 Definitions in Section 8
BUMPER ZONE – the volume contained between two virtual horizontal planes, one inch above the floor and seven inches above the floor. The bumpers must be mounted to satisify this definition. |
Re: Bumper Height
in our rule book we founf it said that it had to be 1 3/16 inches off the ground
Re: Bumper Height
Nope, that's the trailer hitch, at (2 3/16)" from the ground to the horizontal centerline. Al is correct.
Re: Bumper Height
gets hammered?
Re: Bumper Height
That should be two and thirteen sixteenths inches from the floor (2 13/16).
Re: Bumper Height
yes...the nail that sticks out does indeed get hammered....
lol thanks for postin this up... it took me an hour to find it and i learned something.... hahaha i have to make the bumper case for our metal gear titan ... so thanks a bunch.. |
Re: Bumper Height
sooooo...... the bumpers have to be at least 1" above the ground and 7" at max?
Re: Bumper Height
7" minus 1" = 6" so center the nominal 5" tall bumper between the 1 and 7 " mark Read under Robot Rules - Definitions - Bumper Zone Then read <R08> |
#10
Re: Bumper Height
I do not believe that your interpretation is correct. A 6" latitude of placement for a 5" bumper means that the bumpers of two colliding robots could miss each other. This would negate the purpose of the bumper. If your team's robot design requires a 6" latitude, you should post to the FIRST forum for an official ruling. JMHO Mike |
#11
Re: Bumper Height
Once again we have a misunderstanding of the words used in the Manual. First we have the definition:
While the first bolded parts could be read as requiring only the mounting point to be inside the bumper zone, the underlined bold parts specifically say the bumpers themselves must always remain inside the bumper zone. So with a 5" wide bumper, you've got an inch of slop to make sure it stays between 1 and 7 inches from the floor. |
#12
Re: Bumper Height
In my humble opinion, you are correct.
#13
Re: Bumper Height
this whole thread has been both very helpful and confusing im going with higher than one inch and lower than seven? i hope
#14
Re: Bumper Height
<R08-P>: "BUMPERS must be mounted to the ROBOT within the BUMPER ZONE, and must remain there. The BUMPERS must not be articulated or designed to move outside of the BUMPER ZONE." You are correct in your interpretation. |
#15
Re: Bumper Height
This is where the talk about the 5" tall bumper comes into play. (~2.5" pool nodle + ~2.5" pool noodle = ~5" tall bumper.) In my crude picture, let the O's represent a pool noodle cross-section & the solid lines lines above & below the O's equal the 5" spacing between the top & bottom of the constructed BUMPER (height of 2 pool noodles). The dotted line represent your horizontal planes of the BUMPER ZONE limits. ------7" (max) from floor _____ O O___ ------ <-1" (min) from floor ______ <- Floor Hope that clears up any confusion, & doesn't add any more confusion to your understanding of this! ![]() Last edited by Elgin Clock : 06-02-2009 at 15:25. |
| Bumper Height | Zultraranger | Rules/Strategy | 3 | 20-01-2009 23:57 |
| Bumper Height? | EricVicenti | Rules/Strategy | 9 | 14-01-2009 12:23 |
| No height choice? | Molten | General Forum | 12 | 18-01-2008 15:55 |
| Bar Height | Paul H | Rules/Strategy | 3 | 10-01-2004 19:28 |
| Ramp Height?!?!?!?!?! | archiver | 2001 | 4 | 24-06-2002 01:41 |
