Go to Post The Pet Rock was very original, but not necessarily a great thing. - IKE [more]
Unread 24-01-2009, 12:58
angelkat angelkat is offline
FRC #1561
angelkat is an unknown quantity at this point
reading multiple digital inputs
Is there some way to read 8 or so inputs from the digital side car instead of one at a time?
Does anyone have any program for that?
Unread 24-01-2009, 20:09
drkiraco drkiraco is offline
FRC #1747
drkiraco will become famous soon enoughdrkiraco will become famous soon enough
Re: reading multiple digital inputs
no, but it's easy enough for you to write your own. in labview, just set up the program to read each input one at a time. build an array with the results if you feel like it, then drag a box around all 8 reads to highlight then, and do Edit->Create Subvi.
OR
create an array of DigitalInputDeviceRef and then build a For loop to read each one. you can use automatic array indexing to make this very easy
Unread 25-01-2009, 00:22
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
Rookie Year: 2007
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
This works pretty much the same in Windriver--basically, you create a function that updates an array with current values every time it's called, and then use that array.
I'm not quite sure why you would want to do this though--really, the code to read all the inputs at once would be more than the code to read them individually(since you have to store them and retrieve them from an array)
Get yer robot source code here!
Reading NES controller from digital inputs bear24rw Programming 10 07-04-2007 01:17
Digital inputs in autonomous mode? Calvin Programming 8 18-02-2006 13:16
Edu Robot Multiple Inputs jrmarenda Programming 2 24-11-2004 13:22
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
