Go to Post Yeah refs are trained to not have a sense of humor about things like that. - Koko Ed [more]
Unread 24-01-2009, 13:06
tgwicklund tgwicklund is offline
AKA: Thomas Wicklund
FRC #2261 (CASA MESA)
tgwicklund is an unknown quantity at this point
Help getting C++ program to load
I have been trying to get the SimpleTemplate example project to run on the cRio with no luck. I can ping and connect to the cRio and see a list of running tasks, so it's out there. However, when I attempt to debug the program it gives a LONG list of unresolved symbols (about 40 visible on screen of nFPGA methods, the window truncates so I have no idea how many more). Something isn't setup correctly.
I'm told the cRio has been updated properly, but have also been unable to verify this. So specific questions:
  1. I tried undeploy on the chance something was loaded and is interfering. I get an immediate error message:
    "Unable to delete the UserProgram from the robot."
    Does this mean there's nothing loaded or that it isn't talking correctly?
  2. Is there a way to tell what version of cRio software is running and whether it is set for C++ or Labview?
  3. I have tried to re-image the cRio to make sure the correct image is loaded, but the re-image utility cannot find the cRio. It's at the correct 10.22.61.2 address I can ping it, and my firewall is off. Does the re-image utility require that the cRio be set to the default IP address or is there something else I need to do?
Thomas Wicklund
Team 2261
**FIRST EMAIL**/Important Pit Load In and Load Out Information Mark McLeod FIRST E-Mail Blast Archive 7 11-04-2008 08:16
HELP!!!!! Taigene motor load DPTeam270Driver Motors 40 12-02-2008 10:53
**FIRST EMAIL**/Championship Updates - Load In and Load Out and Finale Ticket Inform AmyPrib FIRST E-Mail Blast Archive 3 21-04-2006 11:08
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
Getting program from RC PhatalEphekt Programming 4 18-02-2003 17:44
