Go to Post Weight down low is a good thing. Weight up high is not. - s_forbes [more]
Unread 24-01-2009, 13:53
KRibordy KRibordy is offline
FRC #1000 (Cybearcats)
KRibordy is an unknown quantity at this point
Digital Inputs
After a few days of frustration, I figured out what we were doing wrong with digital inputs. The digital inputs aren't "pulled down" so they read unpredictable values. Our button makes the input read "0" when pushed, which is fine, but when it's NOT pushed, the value fluctuates between 0 and 1. Is there any way we can make the "not pushed" value remain at a constant value?
We just have a switch hooked up to the signal and ground wires of a pwm cable.
Do we need resistors or something else?
reading multiple digital inputs angelkat Programming 2 25-01-2009 00:22
digital inputs: some bad? Trav-O Electrical 3 18-02-2008 23:29
Digital inputs in autonomous mode? Calvin Programming 8 18-02-2006 13:16
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
