Go to Post With all that chain call it Link and dress it up like Zelda. - nuggetsyl [more]
Unread 24-01-2009, 14:06
nayer247 nayer247 is offline
FRC #0247
nayer247 is an unknown quantity at this point
Friction-increasing substances
We're thinking of using a conveyor-system to move balls from the foor to the back and the the top of our robot. Is it legal to apply a friction-increasing substance, like rosin used by violinists on their bows, to the belts to help it grab the balls a bit more?
Thanks
Team 247
Unread 24-01-2009, 14:11
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Friction-increasing substances
Will it damage the balls or leak onto the floor/anything else? If either is true, it's most likely illegal. If neither is true, then it would most likely be legal.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 24-01-2009, 14:13
aznkazoon's Avatar
aznkazoon aznkazoon is offline
FRC #2410 (Metal Mustangs)
Team Role: Marketing
aznkazoon is an unknown quantity at this point
As long as it doesn't affect the ground or the wheels, then your fine. The reason they say to not use other substances is so they can keep the playing field even.
Bam!
Unread 24-01-2009, 14:18
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Like Eric said, it also has to stay off of the balls. If it affects any of the field elements, including game pieces, it will be deemed illegal.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 24-01-2009, 15:19
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
Team Role: Mechanical
joek is an unknown quantity at this point
we're using a similar method, except with hooks, but we tried the method of using 2 belts to compress the ball slightly, and it provides enough friction on it's own... so a friction increasing substance is not needed
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 24-01-2009, 17:24
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Rookie Year: 2007
Ozeaden is an unknown quantity at this point
i think using any kind of chemicals at all that will be a major use on your robot is illegal. wasnt there some rule that said that using any chemicals at all is prohibited? just use velcro or something. it works; my team tested it out and it was pretty good.
http://www.eaglerobotics.com/
Unread 24-01-2009, 18:39
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
No, there isn't.
You are thinking of <R02-I>, which bans caustic chemicals.
Oh, and careful with the velcro: if you damage the balls, you'll have to think of an alternative.
<R34> governs lubricants (or, presumably, additives that could contaminate the field--might be a good idea to Q&A that).
Past teams:
Unread 24-01-2009, 18:59
roboraven15's Avatar
roboraven15 roboraven15 is offline
FRC #1188 (Oaktown Crewz)
Rookie Year: 2007
roboraven15 is an unknown quantity at this point
Send a message via AIM to roboraven15
have you ever consetered velcro? i dont know if thats legal but the rough side could grip ball well
Unread 24-01-2009, 19:57
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
Pretty sure itz legal and no it does not hurt the ball. Make sure you dull the roughing side down a bit and slow rpms on the conveyors. Only advice there. Our whole system is velcro and our balls are in perfect shape, note to all teams.
-rc
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 24-01-2009, 23:22
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
depending on the material (rubber)
there is a spray used on RC tire compounds to make em stickier...i cant remember the name but your local hobby shop may know
Unread 24-01-2009, 23:46
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
I wouldn't use rosin. I bowl, and I have seen rosin go everywhere. It will stick to the balls and most likely get on the floor. It doesn't stick well to any non-fabric materials, and it doesn't stick well to them either. It is designed for keeping hands dry/
Unread 29-01-2009, 10:20
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
What about pine tar like the big leagers use on their bats? Or some kind of friction tape or maybe belt ease?
Bruce
Unread 29-01-2009, 12:04
RMiller RMiller is offline
Taking a Year Off
AKA: Ryan Miller
RMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really niceRMiller is just really nice
I hope not. Everything is a chemical!
2002-2004: 967 Mean Machine
2006-2008: 1816 Green Machine
2008-2010: 2739 Bucket of Bolts (BOB)
Unread 29-01-2009, 12:10
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
<R02> prohibits this type of stuff:
E. Flammable gasses
F. Any devices intended to produce flames or pyrotechnics
G. Materials that off-gas noxious or toxic gasses
H. Materials that produce hazardous inhalable particles
I. Caustic chemicals
J. Hydraulic fluids or hydraulic components
There may be other rules that prohibit more stuff, please read them all and see!
coeficient of friction nickmagus Technical Discussion 4 09-01-2009 01:23
Friction Puzzle Leav Technical Discussion 3 05-01-2009 14:29
Coefficient of Friction VEN Technical Discussion 10 30-12-2006 18:36
Increasing available program memory DanDon Programming 21 30-05-2005 17:00
White Paper Discuss: Increasing A/D Resolution Using Noise CD47-Bot Extra Discussion 7 12-10-2004 09:26
