Go to Post I can follow directions, but if it's not in the directions, I'm lost. - rclothier [more]
Unread 24-01-2009, 16:24
pogenwurst pogenwurst is offline
Ubuntu User
AKA: Brian
FRC #2007 (Robots of the Round Table)
Team Role: Leadership
Rookie Year: 2007
pogenwurst is on a distinguished road
Send a message via AIM to pogenwurst
Moving wheel with shaft
What sort of part can we use instead of bearings so instead of having an AndyMark wheel (the kit sort for previous years) moving freely on a shaft, the wheel turns with the shaft?
Thanks very much
Unread 24-01-2009, 16:37
Joe Finkel Joe Finkel is offline
FRC #0369 (High Voltage)
Team Role: Coach
Rookie Year: 2000
Joe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura aboutJoe Finkel has a spectacular aura about
Re: Moving wheel with shaft
You will have to make a keyed hub.
Unread 24-01-2009, 16:51
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Team Role: Teacher
You don't have to make a keyed hub if you don't want to.
Hi!
Unread 24-01-2009, 17:20
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Team Role: Mechanical
Rookie Year: 2007
Ozeaden is an unknown quantity at this point
you can use igus.
http://www.eaglerobotics.com/
Unread 24-01-2009, 17:26
TUBZ TUBZ is offline
FRC #1622
TUBZ is an unknown quantity at this point
copiously apply epoxy and duct tape to the shaft then swiftly insert it into the wheel hole
WELCOMEZ!!!
SHIZAMLES!!!
Unread 24-01-2009, 22:21
Kraftyman Kraftyman is offline
FRC #0847 (PHRED)
Kraftyman is an unknown quantity at this point
Greetings,
It will depend upon whether you want it completely fixed or not. We keyed our old wheels today with custom hubs similar to one of the above post that you can buy - it works well, but we blew our coupler for the motor. You could try putting an O-ring into the space and make sure it is tight (press a couple in) and it will give you traction with some slip.
KraftyMan
newbie mentor for Nypro Oregon
Unread 27-01-2009, 11:47
Ubuntu User
AKA: Brian
Rookie Year: 2007
Thanks guys, we ordered a few hubs.
Unread 27-01-2009, 12:00
R.C.'s Avatar
Happy Birthday! R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
That's cool and if you have metal shop sponsor they can also make some for u.
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Encoder wheel loose on shaft SuperBK Technical Discussion 1 17-01-2009 11:08
Moving to a point between lights with autonomous minfranco Programming 26 17-02-2007 14:24
Moving robot while tracking with camera questions... Steve Orr Programming 6 02-02-2006 22:24
How do you attach a wheel to a shaft? SilverStar Technical Discussion 21 21-01-2003 19:52
Wheel Attachment to sprocket/shaft? archiver 2000 1 24-06-2002 00:15
