Go to Post "Look, it's already weight optimized!" - Samk [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 24-01-2009, 16:50
unobtainium-42's Avatar
unobtainium-42 unobtainium-42 is offline
Team President
AKA: Eric Eaton
FRC #0670 (Homestead Robotics Team)
unobtainium-42 is an unknown quantity at this point
Windriver does not finish building
We've got a drivable base, updated the hardware and PC software, and I connected to the cRIO over wireless with my laptop. I suspect that I could download new software onto the cRIO. But, when I run a build even with the SimpleRobot example it never seems to finish building. I've given it as long as an hour and nothing new happened No errors, no crashes. The thermometer bar just keeps cycling. Can anyone help me fix this? How long should this take?
This is the Build Output:
Code:
Build Started in Project 'SimpleTemplate':   2009-01-22 19:40:37
Generation of makefiles started.
Generation of makefiles finished (Elapsed Time: 00:01).
Platform: Wind River VxWorks 6.3
Command: make --no-print-directory BUILD_SPEC=PPC603gnu DEBUG_MODE=1 TRACE=1
Working Directory: G:/FRC/2009/Workspace/SimpleTemplate/PPC603gnu
if [ ! -d "`dirname "SimpleTemplate_partialImage/Debug/Objects/SimpleTemplate/MyRobot.o"`" ]; then mkdir -p "`dirname "SimpleTemplate_partialImage/Debug/Objects/SimpleTemplate/MyRobot.o"`"; fi;echo "building SimpleTemplate_partialImage/Debug/Objects/SimpleTemplate/MyRobot.o"; ccppc -g -mcpu=603 -mstrict-align -mno-implicit-fp -mlongcall -ansi -Wall  -MD -MP -mlongcall  -IC:/WindRiver/vxworks-6.3/target/h -IC:/WindRiver/vxworks-6.3/target/h/WPILib -IC:/WindRiver/vxworks-6.3/target/h/wrn/coreip   -DCPU=PPC603 -DTOOL_FAMILY=gnu -DTOOL=gnu -D_WRS_KERNEL    -o "SimpleTemplate_partialImage/Debug/Objects/SimpleTemplate/MyRobot.o" -c "G:/FRC/2009/Workspace/SimpleTemplate/MyRobot.cpp"
You might notice that the files are on G:\. I did it again on a C:\ project and the problem persisted.
While the build is running, a process called get_feature.exe consumes an entire processor (from a dual core). What is it doing
Axis Camera responding in the Vision Assistant but not in WindRiver DanDon C/C++ 3 11-01-2009 12:50
CRIO not working with Windriver dpeterson3 C/C++ 7 07-01-2009 20:49
Where do you actually build your robot and who does the building??? Elgin Clock General Forum 47 14-11-2006 17:50
Not building to do everything?? TriggsJr General Forum 1 02-03-2006 09:06
Project does not build team 803 Programming 5 27-02-2006 17:03
