Go to Post Several really good programming and control specialists haunt CD, but a thread titled "motor failure" might not attract their notice soon. - Richard Wallace [more]
View Poll Results: How fast does your camera tracking run?
1-3 hz 2 3.39%
3-6 7 11.86%
6-9 hz 4 6.78%
9-12 hz 17 28.81%
12-15 hz 7 11.86%
15-18 hz 1 1.69%
18-21 hz 6 10.17%
21-24 hz 2 3.39%
24-27 hz 1 1.69%
27-30 hz 12 20.34%
Voters: 59. You may not vote on this poll
Unread 24-01-2009, 17:39
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
Rookie Year: 2007
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
Speed of the camera
How fast is everyone's color tracking code running when it sees the target?
Unread 24-01-2009, 23:25
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Re: Speed of the camera
Ours runs around 9-10 Hz, probably less, with resolution set to 160x120. Our image processing runs in a separate thread.
Has anyone had better luck with improving processing speed? It'd be great if we could improve the priority of our thread, but that completely screws up the built-in camera task. Would compression help any? The lag time might have to do with GetImage.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 24-01-2009, 23:36
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
Team Role: Leadership
Rookie Year: 2007
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
do you really need to retrieve any video feed? if not rip that code out of the two color tracking demo, if you guys are using that or something similar...
When i ripped out all the camera viewing related code, my camera was moving so smooth it was quite amazing...
Unread 25-01-2009, 01:20
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
What camera viewing related code comes with the two color tracking demo??
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 25-01-2009, 09:56
The major things that affect frame rate are the image size. The images coming from the camera are already compressed JPGs. Large size takes the cRIO 100ms to decode to pixels, medium takes 22ms, and small takes about 8ms. The other impact size has is on the number of pixels to process. To do a color threshold on the large pixmap means processing 307,200 pixels, medium is 1/4th of that, and small is 1/16th that many pixels. These effects added together clearly make image size the primary factor on the frame rate.
The next issue is how the processing is done. There are a number of ways to detect the red/green combo. After looking at a number of them, NI and WPI decided on what is in the example. Other approaches will work, and in fact you may find something even better, but many of the other approaches are slower.
The next issue is the debugging displays. The displays on the PC sent from the cRIO have a pretty big cost. When you need them for debugging, they are certainly worth it, but especially when you are looking at timings, you will want to close subVIs, close probes, and don't leave the HSL debug buttons on in the Find VI either.
As for ripping out the displays, it shouldn't be necessary to rip them out completely. Placing them in a case and only display them when you want them. That way when you want them, you just push a button. Again, that is what the LV examples do.
The last piece I'll comment on for the debugging is the dashboard. The dashboard image display has a button to turn it on and off. In addition, if the dashboard isn't running, is turned off, or is blocked, the loop on the cRIO that is sending the images will block on a TCP call and will not cause any CPU usage. In other words, no need to rip it out either, you can simply turn it off when not needed.
If you'd like to make more precise measurements of where the image processing time is being spent, especially with LV, I'll be glad to help.
Greg McKaskle
Unread 25-01-2009, 12:46
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Rookie Year: 2000
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
For the camera, what value of compression (0-100) would you suggest? What difference, if any, would it make?
Thanks!
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 25-01-2009, 15:02
Feel free to test it.
From my experience, the amount of compression has little impact on framerate. The exceptions I remember were that near 100%, the rate would often drop lower, and near 0%, the same. So keeping it somewhere in the middle, like 20% to 80% has always worked well. The more compression you give, the more blocky the image elements, and IMO the more it will mess with your image processing.
Greg McKaskle
Unread 25-01-2009, 17:38
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
One idea to improve the speed would be to add a separate microprocessor to pre-process the data before sending it to the cRIO.
Unread 25-01-2009, 22:20
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
And how do you plan on sending the data to the cRIO?
You are not allowed (this year) to tap into the ethernet port on the camera side nor are you allowed to use the serial port (*SIGH*).
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 25-01-2009, 22:54
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
You could use a couple of digital IO pins as a serial port. It's been done before...
I observed (on the browser-based camera GUI) that making the image slightly out of focus improved the frame rate. I'm not sure if this is something you would want to do in competition or not.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 29-01-2009, 10:22
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Hmmm, I wonder what the transmission rate of the DIO pins are .....
___________________
- Tennyson, Ulysses
Unread 29-01-2009, 00:30
nickmagus's Avatar
AKA: Nick Clayton
Rookie Year: 2007
who is getting 27-30 hz and what resolution are you using? We are now getting 15-17. but 30 man.
Unread 29-01-2009, 01:17
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
I'm managing around 3-5hz on average at 640x480. It's easier to debug at this size, but I'll probably be cutting it down to 320x240 or smaller for final work.
It's possible to request uncompressed images from the camera... It might be a thought to mess around with that if JPEG decoding becomes the limiting factor here. Although I'm not sure how much network processing is off-loaded on this guy, nor by how much it'd outweigh decoding delay. Uncompressed 900KB vs. 40-60KB compressed. There's also the fact the camera can't (so far as I know) stream BMPs, only request one at a time, so there'd be some extra delay there, although you could use a keep-alive connection...
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 29-01-2009, 09:12
I'm glad to see people looking into the camera capabilities. I'm still doing that myself.
The BMP capabilities on the camera are interesting to look at. What I found was that the time to transmit the much larger file added a delay comparable to the decompression time. You really don't need to worry about the overhead of the http session. The LV camera VIs use the JPEG cgi and do that currently, and the overhead seemed miniscule.
One thing I recently learned which will make its way into a more official document... When playing with the camera settings, the Exposure priority parameter can have a pretty big impact on performance, especially when in normal to lower light. If you set it to image quality, it will avoid bumping the sensor gain and will drastically lower the framerate when there isn't lots of light. When set to framerate, it will bump gain to preserve framerate which will result in grainier images. I haven't done enough testing to see if this has a negative impact on brightly lit usage. Finally, the default of none lets the camera balance this, changing both.
I'd encourage you to look at the performance pretty soon, and if you find something, I'd be glad to hear about it.
Greg McKaskle
  #15   Spotlight this post!
Unread 01-02-2009, 01:15
Cjmovie's Avatar
Greg McKaskle
More so than the HTTP session I'd be worried about the connection creation/destruction each time. Since the the camera literally streams JPEGs pushing them once every time it gets a new image to the connection, it maintains the same connection throughout. Connecting is one of the largest overheads in network systems (when you consider the camera is running a server that probably allocates memory for each call when it's made, etc., slowing things down). Although I do suppose it's all NULL due to the transmission delay on bitmaps as you say. I might investigate this myself later, but only after the base code does everything I'd like it to :-)
Another possibility for speeding it up would be to remember the position of the target between images, and use that as an estimate for where it will be the following time. If you get the cycles fast enough, it shouldn't move too much in between (or, you could even add a simple first-order approximation of position based on current and previous positions). Then find the particles within 50 pixels of the previous spot or such. I'm not sure if it's possible to force cropping on the camera side, but that'd possibly be handy - although, again, probably force constant re-connection (I don't know if the camera supports keep-alive connections. Although it does have a scripting interface...)
Another fun improvement might be to sync the servo movement up with the camera, so that pictures are returned a little less blurred. Or use a gyro to counteract turning of the robot automatically, also lessening blur.
If you wanted to go _really_ in depth, you could take the cropping idea above to a whole second level, and write your own JPEG code to only decode the blocks of the image that you think the target would be in (IIRC from the file format, you'd still have to go through the huffman encoding for the entire image, but you could do the IDCT and such only on the parts you need).
There are literally tons of things I'd like to explore to try and speed up this code. Although, for those interested, my first attempt is going to be to get libjpeg compiled for this processor and see if it's able to decode any faster (although for all I know, NI's JPEG code could easily be based on it, and I'm wasting my time - research is to be done).
Speed of axis camera nickmagus C/C++ 6 18-01-2009 18:25
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Tell the difference: 2007 CMU Camera, 2006, 2005 camera? Chris_Elston Programming 2 07-01-2008 13:11
What speed do you surf the net? Take the test! Elgin Clock IT / Communications 77 30-03-2005 16:28
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
