Go to Post Not that I'm doubting you, but where is it bugged? The exterminators are in the house. - Greg McKaskle [more]
Unread 24-01-2009, 18:28
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
Rookie Year: 2007
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
NiVision.cpp
does anybody know where I can find nivision.cpp? I want to tinker with the blob finding algorithm to make it faster but all I can find is nivision.h.
Unread 25-01-2009, 01:24
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: NiVision.cpp
The NiVision is proprietary, so you can't.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 25-01-2009, 08:33
Re: NiVision.cpp
The NIVision source file is one of several hundred that make up the nivison.out and nivissvc.out binary files. The blob stuff has been around a loooong time, and is very optimized already.
What sorts of things seem slow, or inefficient to you.
Greg McKaskle
Unread 26-01-2009, 00:04
nickmagus's Avatar
AKA: Nick Clayton
Rookie Year: 2007
Re: NiVision.cpp
the color threshold takes a while (relatively) even on the lowest resolution.
Unread 26-01-2009, 08:55
Re: NiVision.cpp
The way the color threshold is being used, we are sending in an RGB image, and asking it to do HSL comparisons. To do this, it converts the pixels to HSL as needed. The largest cost is the hue calculation, so this is done only when the other stuff passes. So in fact, the threshold is doing quite a bit of work. But it is still necessary and fast.
There are of course ways to speed it up. There are functions in the WPI and in the nivision libs for subsetting the image. You can extract a stripe or rect of the image to further limit what the threshold needs to process, and you can decimate the image to grab only every Nth pixel. The speed gain for the threshold call will be directly affected by the number of pixels being processed.
The LV example demonstrates this by using the extract subVI. The trick is to fix up the coordinates on your results. Decimating shrinks the returned coordinates, and subsetting shifts them. So if you implement this in C, it may be useful to look at the LV one for comparison.
Also note that the content of the image and the settings of the Lum and Sat parameters will affect the timings you take. For consistency, take a realistic image, and use it as your test case using a JPG read. The lum and sat speed up the algorithm, because the more pixels that can be excluded with lum and sat, the fewer hue calculations are needed.
Greg McKaskle
Fatal Error: Cannot access Resource.cpp darkdwarven FRC Control System 2 26-01-2009 18:50
